Thermal conductivities for some common liquids at temperature 300 K (26.8 oC, 80.3 oF):
Fluid | Thermal Conductivity (W/m K) |
Acetic acid | 0.193 |
Acetone | 0.180 |
Alcohol, ethyl (ethanol) | 0.171 |
Alcohol, methyl (methanol) | 0.204 |
Alcohol, propyl | 0.161 |
Ammonia, saturated | 0.507 |
Aniline | 0.172 |
Antifreeze-water mixture 38% | 0.45 |
Benzene | 0.167 |
Benzine | 0.16 |
Carbon Disulfide | 0.161 |
Carbon Tetrachloride | 0.104 |
Castor Oil | 0.180 |
Chloroform | 0.129 |
Decane | 0.147 |
Dichlorodifluoromethane refrigerant R-12 | 0.071 |
Diesel oil | 0.13 |
Dodecane | 0.140 |
Engine Oil, unused | 0.145 |
Ethanol | 0.17 |
Ether | 0.130 |
Ethyl acetate | 0.137 |
Ethyl chloride | 0.11 |
Ethyl ether | 0.13 |
Ethylene glycol | 0.258 |
Fuel oil | 0.14 |
Gasoline, petrol | 0.13 |
Glycerine | 0.285 |
Heating oil | 0.12 |
Hexane | 0.124 |
Hydrochloric acid 10% | 0.50 |
Hydrofluoric acid | 2.33 |
Isobutyl alcohol | 0.134 |
Kerosene (paraffin) | 0.145 |
Linseed oil | 0.15 |
Lubricating Machine oil | 0.126 |
Medicinal paraffin | 0.127 |
Mercury | 8.4 |
Methane (93.2 K) | 0.2153 |
Methanol | 0.2 |
n-Butyl alcohol | 0.167 |
n-Heptane | 0.140 |
n-Octane | 0.147 |
n-Pentane | 0.136 |
n-Propyl alcohol | 0.168 |
Nitric acid | 0.26 |
Nitrogen (69.1 K) | 0.1511 |
Oil, cylinder | 0.152 |
Oil, transformer | 0.136 |
Petroleum | 0.159 |
Petroleum ether | 0.14 |
Phenol | 0.190 |
Propylene glycol | 0.147 |
Salt solution 20% | 0.58 |
Sulfuric acid concentrated | 0.5 |
Tar | 0.19 |
Toluene | 0.151 |
Transformer oil | 0.13 |
Trichlor ethylene | 0.16 |
Trichlorofluoromethane refrigerant R-11 | 0.093 |
Turpentine oil | 0.128 |
Water, Fresh | 0.609 |
Xenon (173 K) | 0.07 |
- 1 W/(m K) = 1 W/(m oC) = 0.85984 kcal/(h m oC) = 0.5779 Btu/(ft h oF) = 0.048 Btu/(in h oF)
- Thermal Conductivity Converter
• Thermodynamics
Antifreeze - Ethylene Glycol Volume vs. Temperature Rating
Freeze protecting of cooling systems - temperature rating vs. required amount of antifreeze.
Conductive Heat Transfer
Online calculator, figures and tables showing thermal conductivity of nitrogen, N2, at varying temperarure and pressure, SI and Imperial units.
Nitrogen - Thermal Diffusivity vs. Temperature and Pressure
Figures and tables showing thermal diffusivity of nitrogen at varying temperarure and pressure, SI and Imperial units.
Thermal conductivity of plastics.
Thermal Conductivity of Common Materials - Solids, Liquids and Gases
Thermal conductivity of various common materials, including metals, gases, and building materials. Essential data for engineers, architects, and designers working with heat transfer and insulation.
Thermal Conductivity Units Converter
