Thermal conductivities for some common liquids at temperature 300 K (26.8 oC, 80.3 oF):
FluidThermal Conductivity
(W/m K)
Acetic acid 0.193
Acetone 0.180
Alcohol, ethyl (ethanol) 0.171
Alcohol, methyl (methanol) 0.204
Alcohol, propyl 0.161
Ammonia, saturated 0.507
Aniline 0.172
Antifreeze-water mixture 38% 0.45
Benzene 0.167
Benzine 0.16
Carbon Disulfide 0.161
Carbon Tetrachloride 0.104
Castor Oil 0.180
Chloroform 0.129
Decane 0.147
Dichlorodifluoromethane refrigerant R-12 0.071
Diesel oil 0.13
Dodecane 0.140
Engine Oil, unused 0.145
Ethanol 0.17
Ether 0.130
Ethyl acetate 0.137
Ethyl chloride 0.11
Ethyl ether 0.13
Ethylene glycol 0.258
Fuel oil 0.14
Gasoline, petrol 0.13
Glycerine 0.285
Heating oil 0.12
Hexane 0.124
Hydrochloric acid 10% 0.50
Hydrofluoric acid 2.33
Isobutyl alcohol 0.134
Kerosene (paraffin) 0.145
Linseed oil 0.15
Lubricating Machine oil 0.126
Medicinal paraffin 0.127
Mercury 8.4
Methane (93.2 K) 0.2153
Methanol 0.2
n-Butyl alcohol 0.167
n-Heptane 0.140
n-Octane 0.147
n-Pentane 0.136
n-Propyl alcohol 0.168
Nitric acid 0.26
Nitrogen (69.1 K) 0.1511
Oil, cylinder 0.152
Oil, transformer 0.136
Petroleum 0.159
Petroleum ether 0.14
Phenol 0.190
Propylene glycol 0.147
Salt solution 20% 0.58
Sulfuric acid concentrated 0.5
Tar 0.19
Toluene 0.151
Transformer oil 0.13
Trichlor ethylene 0.16
Trichlorofluoromethane refrigerant R-11 0.093
Turpentine oil 0.128
Water, Fresh 0.609
Xenon (173 K) 0.07
