Thermal Conductivity Units Converter
Thermal conductivity - k - indicates a materials ability to conduct heat.
| Convert from | Multiply with | ||||
| Convert to | |||||
| Btu ft / (h ft2 oF) | Btu in / (h ft2 oF) | Btu in / sec ft2 oF) | Cal / (cm s oC) | Kcal / (cm s oC) | |
| Btu ft / (h ft2 oF) | 1 | 12 | 0.0033 | 0.0041 | 4.134×10-6 |
| Btu in / (h ft2 oF) | 0.0833 | 1 | 0.000278 | 0.00035 | 3.45×10-7 |
| Btu in / (sec ft2 oF) | 300 | 3600 | 1 | 1.24 | 0.0012 |
| Cal / (cm s oC) | 241.9 | 2903 | 0.806 | 1 | 0.001 |
| Kcal / (cm s oC) | 2.42×105 | 2.9×106 | 806.3 | 1000 | 1 |
| Kcal / (m h oC) | 0.672 | 8.06 | 0.0022 | 0.00278 | 2.778×10-6 |
| Erg / (cm s oC) | 5.78×106 | 6.93×10-5 | 1.92×10-8 | 2.39×10-8 | 2.389×10-11 |
| Joules / (m h oC) | 1.61×10-4 | 0.00193 | 5.35×10-7 | 6.64×10-7 | 6.635×10-10 |
| Watt / (ft oC) | 1.89 | 22.8 | 0.0078 | 0.0078 | 7.84×10-6 |
| Watt / (m K) | 0.58 | 6.94 | 0.00193 | 0.0024 | 2.39×10-6 |
| Convert to | |||||
| Kcal / (m h oC) | Erg / (cm s oC) | Joules / (m h oC) | Watt / (ft oC) | Watt / (m K) | |
| Btu ft / (h ft2 oF) | 1.49 | 173076 | 6230 | 0.527 | 1.73 |
| Btu in / (h ft2 oF) | 0.124 | 14423 | 519 | 0.044 | 0.14 |
| Btu in / (sec ft2 oF) | 446.5 | 5.19×107 | 1.87×106 | 158.2 | 519 |
| Cal / (cm s oC) | 360 | 4.19×107 | 1.51×106 | 127.6 | 418 |
| Kcal / (cm s oC) | 360000 | 4.19×1010 | 1.51×109 | 1.276×105 | 4.18×105 |
| Kcal / (m h oC) | 1 | 116300 | 4187 | 0.354 | 1.16 |
| Erg / (cm s oC) | 8.6×10-6 | 1 | 0.036 | 3.05×10-6 | 1×10-5 |
| Joules / (m h oC) | 0.00024 | 27.78 | 1 | 8.47×10-5 | 2.78×10-4 |
| Watt / (ft oC) | 2.82 | 328123 | 11811 | 1 | 3.28 |
| Watt / (m K) | 0.86 | 1×105 | 3600 | 0.305 | 1 |
Thermal Conductivity - Unit Converter Chart
Download and print Thermal Conductivity - Unit Converting Chart
• Thermodynamics
Calcium Silicate Insulation
Thermal conductivity of calcium silicate insulation - temperature and k-values.
Conductive Heat Transfer
Typical heat exchanger materials and their thermal conductivities.
Mineral Wool Insulation
Online calculator, figures and tables showing thermal conductivity of nitrogen, N2, at varying temperarure and pressure, SI and Imperial units.
Thermal Conductivity of Common Materials - Solids, Liquids and Gases
Thermal conductivity of various common materials, including metals, gases, and building materials. Essential data for engineers, architects, and designers working with heat transfer and insulation.
