Thermal conductivities of some commonly used heat exchanger materials:
Material | Thermal Conductivity (W/m oC) |
Admiralty (71 Cu - 28 Zn - 1 Sn) | 111 |
Aluminum | 205 - 250 |
Aluminum brass (76 Cu - 22 Zn - 2 Al) | 100 |
Brass (70 Cu - 30 Zn) | 99 |
Carbon Steel | 45 |
Carbon-moly (0.5 Mo) | 43 |
Chrome-moly steel (1 Cr - 0.5 Mo) | 42 |
Chrome-moly steel (2 1/4 Cr - 0.5 Mo) | 38 |
Chrome-moly steel (5 Cr - 0.5 Mo) | 35 |
Chrome-moly steel (12 Cr - 1 Mo) | 28 |
Copper | 386 |
Cupro-nickel (90 Cu - 10 Ni) | 71 |
Cupro-nickel (70 Cu - 30 Ni) | 29 |
Inconel | 19 |
Lead | 35 |
Monel (67 Ni - 30 Cu - 1.4 Fe) | 26 |
Nickel | 62 |
Polypropylene | 0.1 - 0.22 |
Red Brass (85 Cu - 15 Zn) | 159 |
Stainless Steel, type 316 (17 Cr - 12 Ni - 2 Mo) | 16 |
Stainless Steel, type 304 (18 Cr - 8 Ni) | 16 |
Titanium | 19 |
• Thermodynamics
Composition of Steels
Typical composition of AISI steels.
Heat Exchangers - Overall Heat Transfer Coefficients
Overall heat transfer coefficients in common heat exchanger designs - tubular, plate or spiral.
Metals, Metallic Elements and Alloys - Thermal Conductivities
Thermal conductivities of common metals, metallic elements aand alloys.
Nickel Binary Eutectic Alloys - Melting Points
Ni - Nickel - binary eutectic alloys and melting points.
Online calculator, figures and tables showing thermal conductivity of nitrogen, N2, at varying temperarure and pressure, SI and Imperial units.
Thermal conductivity of plastics.
Thermal conductivity coefficients for insulation materials, aluminum, asphalt, brass, copper, steel, gases and more.
Thermal Conductivity Unit Converter
