Melting point is the temperature at which a substance changes from solid to liquid state.
Melting points for some metals and alloys:
| Metal | Melting Temperature (oC) |
| Admiralty Brass | 900 - 940 |
| Aluminum | 660 |
| Aluminum Alloy | 463 - 671 |
| Aluminum Bronze | 1027 - 1038 |
| Antimony | 630 |
| Babbitt | 249 |
| Beryllium | 1285 |
| Beryllium Copper | 865 - 955 |
| Bismuth | 271.4 |
| Brass, Red | 1000 |
| Brass, Yellow | 930 |
| Cadmium | 321 |
| Chromium | 1860 |
| Cobalt | 1495 |
| Copper | 1084 |
| Cupronickel | 1170 - 1240 |
| Gold, 24K Pure | 1063 |
| Hastelloy C | 1320 - 1350 |
| Inconel | 1390 - 1425 |
| Incoloy | 1390 - 1425 |
| Indium | 156.6 |
| Iridium | 2450 |
| Iron, Wrought | 1482 - 1593 |
| Iron, Gray Cast | 1127 - 1204 |
| Iron, Ductile | 1149 |
| Lead | 327.5 |
| Magnesium | 650 |
| Magnesium Alloy | 349 - 649 |
| Manganese | 1244 |
| Manganese bronze | 865 - 890 |
| Mercury | -38.86 |
| Molybdenum | 2620 |
| Monel | 1300 - 1350 |
| Nickel | 1453 |
| Niobium (Columbium) | 2470 |
| Osmium | 3025 |
| Palladium | 1555 |
| Phosphorus | 44 |
| Platinum | 1770 |
| Plutonium | 640 |
| Potassium | 63.3 |
| Red Brass | 990 - 1025 |
| Rhenium | 3186 |
| Rhodium | 1965 |
| Ruthenium | 2482 |
| Selenium | 217 |
| Silicon | 1411 |
| Silver, Coin | 879 |
| Silver, Pure | 961 |
| Silver, Sterling | 893 |
| Sodium | 97.83 |
| Solder 50 - 50 | 215 |
| Steel, Carbon | 1425 - 1540 |
| Steel, Stainless | 1510 |
| Tantalum | 2980 |
| Thorium | 1750 |
| Tin | 232 |
| Titanium | 1670 |
| Tungsten | 3400 |
| Uranium | 1132 |
| Vanadium | 1900 |
| Yellow Brass | 905 - 932 |
| Zinc | 419.5 |
| Zirconium | 1854 |
Gold, Silver and Copper - Pressure and Melting Temperatures
Aluminum - Melting Points of Binary Eutectic Alloys
Al - Aluminum - binary eutectic alloys and their melting points.
Aluminum Alloys - Mechanical Properties
Mechanical properties of some common aluminum alloys.
Mechanical properties of aluminum alloys - tensile strength, yield strength and more.
Arsenic - Melting Points of Binary Eutectic Alloys
As - Arsenic - binary eutectic alloys and their melting points.
ASTM B43 - Seamless Red Brass Pipes - Dimensions
Standard sizes specification for seamless red brass pipes.
Beryllium - Specific Heat vs. Temperatures
Specific heat of beryllium related to temperature.
Bronze Flanges - ASME/ANSI 150 lb
Flange diameters, thickness, bolt circles, numbers and diameters of bolts for ASME/ANSI B16.15 - Cast Bronze Threaded Fittings - 150 lb Bronze flanges with plain faces.
Carbon Steel Flanges - Group 1.1 Pressure and Temperature Ratings
Maximum temperature and pressure ratings of flanges conforming dimensions ASME B16.5 and materials specification ASTM A-105.
Copper Binary Eutectic Alloys - Melting Points
Cu - Copper - binary eutectic alloys and their melting points.
Copper, Zinc and Tin Alloys
Strength of Copper, Zinc and Tin alloys.
Gold Binary Eutectic Alloys - Melting Points
Some Au - Gold - binary eutectic alloys and their melting points.
Iron Binary Eutectic Alloys - Melting Points
Fe - Iron - binary eutectic alloys and melting points.
Lead Binary Eutectic Alloys - Melting Points
Pb - Lead (Plumbum) - binary eutectic alloys and melting points.
Magnesium Binary Eutectic Alloys - Melting Points
Mg - Magnesium - binary eutectic alloys and melting points.
Metal Alloys - Melting Points
Alloys and their melting points.
Metal Alloys - Specific Heats
Specific heat of metal alloys like brass, bronze and more.
Metals - Boiling Temperatures
Metals and their boiling temperatures.
Metals - Latent Heat of Melting
Metals and their latent heat of fusion.
Metals - Machinability
The machinability of some common metals.
Metals - Specific Heats
Metals and Alloys - Densities
Metals Strength vs. Temperature
The influence of temperature on the strength of metals.
Molybdenum Binary Eutectic Alloys - Melting Points
Mo - Molybdenum - binary eutectic alloys and melting points.
Nickel Binary Eutectic Alloys - Melting Points
Ni - Nickel - binary eutectic alloys and melting points.
Poisson's Ratios Metals
Silver Binary Eutectic Alloys - Melting Points
Ag - Silver - binary eutectic alloys and melting points.
Solids and Metals - Specific Gravities
Specific gravity for common solids and metals like aluminum, asbestos, brass, calcium and many others.
Stainless Steel - Comparing International Standards
Comparing international stainless steel standards from America (US), France, Germany, Italy, Japan, Russia, Spain, Sweden, England (UK) and the European Union.
Steel Tempering Colors
The tempering process of hardening steel.
Welding Temperatures
Melting and welding temperatures.
