Metal Alloys - Melting Points
An alloy is a mixture of metals or a mixture of a metal and another element. Melting points of some mixtures of metals are indicated in the diagrams below:
Lead - Pb
Melting points of Pb - Lead - in mixtures with
  • Sn - Tin
  • Bi - Bismuth
  • Te - Tellurium
  • Ag - Silver
  • Na - Sodium - Natrium
  • Cu - Copper
  • Sb - Antimony
Aluminum - Al
Melting points of Al - Aluminum - in mixtures with
  • Sb - Antimony
  • Cu - Copper
  • Au - Gold
  • Ag - Silver
  • Zn - Zinc
  • Fe - Iron
  • Sn - Tin
Copper - Cu
Melting points of Cu - Copper - in mixtures with
  • Ni - Nickel
  • Ag - Silver
  • Sn - Tin
  • Zn - Zinc
Antimony - Sb
Melting points of Sb - Antimony - in mixtures with
  • Bi - Bismuth
  • Ag - Silver
  • Sn - Tin
  • Zn - Zinc
Material Properties
Melting and Freezing Points
Aluminum - Melting Points of Binary Eutectic Alloys
Al - Aluminum - binary eutectic alloys and their melting points.
Arsenic - Melting Points of Binary Eutectic Alloys
As - Arsenic - binary eutectic alloys and their melting points.
Copper Binary Eutectic Alloys - Melting Points
Cu - Copper - binary eutectic alloys and their melting points.
Copper, Zinc and Tin Alloys
Strength of Copper, Zinc and Tin alloys.
Gold Binary Eutectic Alloys - Melting Points
Some Au - Gold - binary eutectic alloys and their melting points.
Hydrocarbons - Physical Data
Iron Binary Eutectic Alloys - Melting Points
Fe - Iron - binary eutectic alloys and melting points.
Lead Binary Eutectic Alloys - Melting Points
Pb - Lead (Plumbum) - binary eutectic alloys and melting points.
Magnesium Binary Eutectic Alloys - Melting Points
Mg - Magnesium - binary eutectic alloys and melting points.
Metal Alloys - Specific Heats
Specific heat of metal alloys like brass, bronze and more.
Molybdenum Binary Eutectic Alloys - Melting Points
Mo - Molybdenum - binary eutectic alloys and melting points.
Nickel Binary Eutectic Alloys - Melting Points
Ni - Nickel - binary eutectic alloys and melting points.
