Gold Binary Eutectic Alloys - Melting Points
The melting point of an alloy of two (binary) or more metals depends on the relative proportions of the ingredients.
  • an eutectic mixture is the mixture where the melting point is as low as possible
Binary eutectic Gold - Au - alloys, with composition and melting points are indicated below:
Alloy ComponentWeight of Alloy Component
Melting Point
KoF
Bi - Bismuth 85 514 466
Cd - Cadmium 57 773 932
Ce - Cerium 81 793 968
Ge - Germanium 12 629 673
La - Lanthanum 78 834 1042
Mg - Magnesium 62 848 1067
Mn - Manganese 12 1233 1760
Na - Sodium (Natrium) 2.3 1149 1609
Pb - Lead (Plumbum) 85 488 419
Sb - Antimony (Stibium) 24.8 633 680
Si - Silicon 3.15 636 685
Sn - Tin (Stannum) 19.9 551 532
Te - Tellurium 83 689 781
Tl - Thallium 73 404 268
U - Uranium 16 1128 1571
  • T (oC) = 5/9 (T (oF) - 32)
Material Properties
Aluminum - Melting Points of Binary Eutectic Alloys
Al - Aluminum - binary eutectic alloys and their melting points.
Copper Binary Eutectic Alloys - Melting Points
Cu - Copper - binary eutectic alloys and their melting points.
Liquids - Freezing and Melting Points
Common fluids and their freezing and melting points.
Melting and Boiling Temperatures - Evaporation and Melting Heats common Materials
Melting and boiling point temperatures, latent heat of evaporation, and melting heat of common substances like copper, gold, lead and more - SI units.
Metal Alloys - Melting Points
Alloys and their melting points.
Molybdenum Binary Eutectic Alloys - Melting Points
Mo - Molybdenum - binary eutectic alloys and melting points.
Solids - Melting and Boiling Temperatures
Melting and boiling temperatures of some products.
