Copper Binary Eutectic Alloys - Melting Points
The melting point of an alloy of two (binary) or more metals depends on the relative proportions of the ingredients.
  • an eutectic mixture is the mixture where the melting point is as low as possible
Binary eutectic Copper - Cu - alloys, with composition and melting points are indicated below:
Alloy ComponentWeight of Alloy Component
Melting Point
KoF
Ge - Germanium 37 913 1184
Mg - Magnesium 69.3 758 905
Mn - Manganese 34 1143 1598
Pb - Lead (Plumbum) 36 1230 1755
Pr - Praseodymium 83 745 882
Sb - Antimony (Stibium) 76 800 981
Si - Silicon 16 1075 1476
Te - Tellurium 82 617 207
Ti - Titanium 22 1133 1580
Tl - Thallium 35.3 1357 1983
U - Uranium 25 1213 1724
Zr - Zirconium 13 1253 1796
  • T (oC) = 5/9 (T (oF) - 32)
Material Properties
Melting and Freezing Points
Copper - Density, Specific Heat and Thermal Conductivity vs. Temperature
Density, specific heat and thermal conductivity of copper vs. temperature
Elements - Melting Points
Melting points of elements.
Gold Binary Eutectic Alloys - Melting Points
Some Au - Gold - binary eutectic alloys and their melting points.
Liquids - Freezing and Melting Points
Common fluids and their freezing and melting points.
Magnesium Binary Eutectic Alloys - Melting Points
Mg - Magnesium - binary eutectic alloys and melting points.
Metal Alloys - Melting Points
Alloys and their melting points.
Metals - Boiling Points and Specific Heat
Boiling points and specific heat of liquid metals.
Molybdenum Binary Eutectic Alloys - Melting Points
Mo - Molybdenum - binary eutectic alloys and melting points.
Salt Hydrates - Melting points and Latent Melting Energy
Melting points and latent energy of salt hydrates.
Solids - Melting and Boiling Temperatures
Melting and boiling temperatures of some products.
