Magnesium Binary Eutectic Alloys - Melting Points
The melting point of an alloy of two (binary) or more metals depends on the relative proportions of the ingredients.
- an eutectic mixture is the mixture where the melting point is as low as possible
Binary eutectic Magnesium - Mg - alloys, with composition and melting points are indicated below:
Alloy Component | Weight of Alloy Component (%) | Melting Point | |
K | oF | ||
Ni - Nickel | 23 | 780 | 945 |
Pr - Praseodymium | 23 | 858 | 1085 |
Pu - Plutonium | 63 | 815 | 1008 |
Sb - Antimony (Stibium) | 97 | 855 | 1080 |
Si - Silicon | 57 | 1223 | 1742 |
Sr - Strontium | 89 | 699 | 799 |
Th - Thorium | 42 | 855 | 1080 |
Zn - Zinc | 53 | 615 | 648 |
- T (oC) = 5/9 (T (oF) - 32)
Aluminum - Melting Points of Binary Eutectic Alloys
Al - Aluminum - binary eutectic alloys and their melting points.
Copper Binary Eutectic Alloys - Melting Points
Cu - Copper - binary eutectic alloys and their melting points.
Metal Alloys - Melting Points
Alloys and their melting points.
Metals - Boiling Temperatures
Metals and their boiling temperatures.
Metals - Latent Heat of Melting
Metals and their latent heat of fusion.
Metals - Specific Heats
Metals and Alloys - Densities
Molybdenum Binary Eutectic Alloys - Melting Points
Mo - Molybdenum - binary eutectic alloys and melting points.
Nickel Binary Eutectic Alloys - Melting Points
Ni - Nickel - binary eutectic alloys and melting points.
