Density, specific heat and thermal conductivity related to temperature.
Mechanical properties of aluminum alloys - tensile strength, yield strength and more.
Melting points of elements.
Some Au - Gold - binary eutectic alloys and their melting points.
Fe - Iron - binary eutectic alloys and melting points.
Pb - Lead (Plumbum) - binary eutectic alloys and melting points.
Common fluids and their freezing and melting points.
Mg - Magnesium - binary eutectic alloys and melting points.
Alloys and their melting points.
Melting and boiling point temperatures, latent heat of evaporation, and melting heat of common substances like copper, gold, lead and more - SI units.
Mo - Molybdenum - binary eutectic alloys and melting points.
Melting points and latent energy of salt hydrates.
