Elements - Melting Points
The Elements - Melting Points
ElementSymbolMelting Point
(oC)
Actinium Ac 1050
Aluminum Al 660.37
Americum Am 994 +- 4
Antimony  Sb 630.74
Argon  A -189.2
Arsenic  As 817 (at 28 atm)
Astatine  At 302
Barium  Ba 725
Berkelium  Bk
Beryllium  Be 1278 +- 5
Bismuth  Bi 271.3
Boron  B 2079
Bromine  Br -7.2
Cadmium  Cd 320.9
Calcium  Ca 839 +-2
Californium  Cf
Carbon  C 3652 (sublimates)
Cerium  Ce 798 +- 2
Cesium  Cs 28.4 +- 0.01
Chlorine  Cl -100.98
Chromium  Cr 1857 +- 20
Cobalt  Co 1495
Copper  Cu 1083.4 +- 0.2
Curium  Cm 1340 +- 40
Dysprosium  Dy 1409
Einsteinium  Es
Erbium  Er 1522
Europium  Eu 822 +- 5
Fermium  Fm
Fluorine  F -219.62
Francium  Fr 677
Gadolinium  Gd 1311 +- 1
Gallium  Ga 29.78
Germanium  Ge 937.4
Gold  Au 1064.434
Hafnium  Hf 2227 +- 20
Helium  He -272.2 (at 26 atm)
Holmium  Ho 1470
Hydrogen  H -259.14
Indium  In 156.61
Iodine  I 113.5
Iridium  Ir 2410
Iron  Fe 1535
Krypton  Kr -156.6
Lanthanum  La 920 +- 5
Lawrencium  Lw
Lead  Pb 327.502
Lithium  Li 180.54
Lutetium  Lu 1656 +- 5
Magnesium Mg 648.8 +- 0.5
Manganese Mn 1244 +- 2
Mendelevium Md
Mercury Hg -38.87
Molybdenum Mo 2617
Neodymium Nd 1010
Neon Ne -248.67
Neptunium Np 640 +- 1
Nickel Ni 1453
Niobium Nb 2468 +- 10
Nitrogen N -209.86
Nobelium No
Osmium Os 3045 +- 30
Oxygen O -218.4
Palladium Pd 1554
Phosphorus P 44.1
Platinum Pt 1772
Plutonium Pu 641
Polonium Po 254
Potassium K 63.25
Praseodymium Pr 931 +- 4
Promethium Pm 1080
Protactinium Pa 1600
Radium Ra 700
Radon Rn -71
Rhenium Re 3180
Rhodium Rh 1965 +- 3
Rubidium Rb 38.89
Ruthenium Ru 2310
Samarium Sm 1072 +- 5
Scandium Sc 1539
Selenium Se 217
Silicon Si 1410
Silver Ag 961.93
Sodium Na 97.81 +- 0.03
Strontium Sr 769
Sulphur S 112.8
Tantalum Ta 2996
Technetium Tc 2172
Tellurium Te 449.5 +- 0.3
Terbium Tb 1360 +- 4
Thallium Tl 303.5
Thorium Th 1750
Thulium Tm 1545 +- 15
Tin Sn 231.9681
Titanium Ti 1660 +- 10
Tungsten W 3410 +- 20
Uranium U 1132 +- 0.8
Vanadium V 1890 +- 10
Xenon Xe -111.9
Ytterbium Yb 824 +- 5
Yttrium Y 1523
+- 8
Zinc Zn 419.58
Zirconium Zr 1852 +- 2
Material Properties
Melting and Freezing Points
Aluminum - Melting Points of Binary Eutectic Alloys
Al - Aluminum - binary eutectic alloys and their melting points.
Arsenic - Melting Points of Binary Eutectic Alloys
As - Arsenic - binary eutectic alloys and their melting points.
Copper Binary Eutectic Alloys - Melting Points
Cu - Copper - binary eutectic alloys and their melting points.
Elements - Boiling Points
Elements and their boiling points.
Iron Binary Eutectic Alloys - Melting Points
Fe - Iron - binary eutectic alloys and melting points.
Lead Binary Eutectic Alloys - Melting Points
Pb - Lead (Plumbum) - binary eutectic alloys and melting points.
Molybdenum Binary Eutectic Alloys - Melting Points
Mo - Molybdenum - binary eutectic alloys and melting points.
Nickel Binary Eutectic Alloys - Melting Points
Ni - Nickel - binary eutectic alloys and melting points.
