Lead Binary Eutectic Alloys - Melting Points
The melting point of an alloy of two (binary) or more metals depends on the relative proportions of the ingredients.
- an eutectic mixture is the mixture where the melting point is as low as possible
Binary eutectic Lead - Pb - alloys, with composition and melting points are indicated below:
Alloy Component | Weight of Alloy Component (%) | Melting Point | |
K | oF | ||
Pr - Praseodymium | 31 | 1315 | 1908 |
Pt - Platinum | 5 | 563 | 554 |
Sb - Antimony (Stibium) | 11 | 520 | 477 |
Sn - Tin (Stannum) | 61 | 460 | 369 |
Te - Tellurium | 78 | 680 | 765 |
Ti - Titanium | 74 | 998 | 1337 |
- T (oC) = 5/9 (T (oF) - 32)
Aluminum - Melting Points of Binary Eutectic Alloys
Al - Aluminum - binary eutectic alloys and their melting points.
Elements - Melting Points
Melting points of elements.
Metal Alloys - Melting Points
Alloys and their melting points.
Metals - Boiling Points and Specific Heat
Boiling points and specific heat of liquid metals.
Metals - Latent Heat of Melting
Metals and their latent heat of fusion.
Metals - Specific Heats
Metals and Alloys - Densities
