Melting and Boiling Temperatures - Evaporation and Melting Heats common Materials
Melting and boiling temperatures, latent heat of evaporation, and melting heat from solid to fluid state of common substances:
SubstanceMelting Point Temperature
- t -
(oC)
Latent Heat of Melting
- Lf -
(kJ/kg)
Boiling Point - Vaporization -  Temperature
- t -
(oC)
Latent Heat of Evaporation
- Lv -
(kJ/kg)
Aluminum 659 399 2327 10530
Brass 930
Cobalt 1480   2900
Copper 1083 207 2595 4730
Ethyl alcohol -114 108 78.3 855
Gold 1063 64 2600 1577
Graphite     3500
Hydrogen -259 58.0 -253 455
Iron 1149 247 2870
Lead 328 23 1750 859
Manganese 1260   2150
Magnesium 650   1110
Mercury -38.8 11 357 295
Molybdenum 2620   5560
Nickel 1455   2730
Nitrogen -210 25.7 -196 200
Oxygen -219 13.9 -183 213
Silver 962 111 1950 2356
Titanium 1700   3260
Tungsten 3370   5930
Zinc 420   906
Water 0 335 100 2272
  • tC = 5/9 (tF - 32)
  • 1 kJ/kg = 0.4299 Btu/ lbm = 0.23884 kcal/kg
Boiling Points of Fluids
Material Properties
Melting and Freezing Points
Aluminum - Melting Points of Binary Eutectic Alloys
Al - Aluminum - binary eutectic alloys and their melting points.
Gold Binary Eutectic Alloys - Melting Points
Some Au - Gold - binary eutectic alloys and their melting points.
Hydrocarbons - Physical Data
Latent Heat Flow
Liquids - Latent Heat of Evaporation
Latent heat of vaporization for fluids like alcohol, ether, nitrogen, water and more.
