  • Boiling point - the temperature at which a liquid turns into a gas
  • Melting point - the temperature at which a solid turns into a liquid
See Standard state and enthalpy of formation, Gibbs free energy of formation, entropy and heat capacity for thermodynamic data for the same compounds
For full table with Density, Liquid Denity at  Melting Point and Water Solubility- rotate the screen!
Substance Formula > Melting point
°C
Boiling temperature
°C
Density
@25°C
g/cm 3
Liquid density
@Melting point
g/cm 3
Water solubility
@25°C 1)
g/100g H 2 O
Comments (*)
Aluminium Al 660.3 2519 2.7 2.77
Aluminium bromide AlBr 3 97.5 255 3.2 2.647
Aluminium chloride AlCl 3 192.6 sub 180 2.48 1.302 45
Aluminium fluoride AlF 3 tp 2250* sub 1276 3.1 0.5 @220 Mpa
Aluminium hydroxide Al(OH) 3 2.42
Aluminium iodide AlI 3 188.28 382 3.98 3.223
Aluminium oxide Al 2 O 3 2053 2977 3.99
Aluminium phosphate AlPO 4 >1460 2.56
Ammonium NH 3 -77.65 -33.33 0.7329* liquid @-77.7°C
Ammonium chloride NH 4 Cl tp 520.1 sub 338 1.519 39.5
Ammonium nitrate NH 4 NO 3 169.7 d 200-260 1.72 213
Ammonium sulfate (NH 4 ) 2 SO 4 d 280 1.77 76.4
Boron B 2077 40000 2.34 2.08
Boron fluoride BF 3 -126.8 -99.9 0.002772* gas @25°C
Boron sulfide B 2 S 3 563 ~1.7
Barium Ba 727 ~1845 3.62 3.338
Barium bromide BaBr 2 857 1835 4.781 3.991 100
Barium carbonate BaCO 3 1555 4.308 0.0014 20
Barium chloride BaCl 2 961 1560 3.9 3.174 37
Barium fluoride BaF 2 1368 2260 4.893 4.14 0.161
Barium hydride BaH 2 1200 4.16
Barium iodide BaI 2 711 5.15 4.26 221
Barium oxide BaO 1973 5.72 1.5 20
Barium sulfate BaSO 4 1580 4.49 0.00031 20
Beryllium Be 1287 2468 1.85 1.69
Beryllium bromide BeBr 2 508 sub 473 3.465
Beryllium chloride BeCl 2 415 482 1.9 1.54 71.5
Beryllium fluoride BeF 2 552 1283 2.1 1.96
Beryllium hydroxide Be(OH) 2 d ~200 1.92
Beryllium iodide BeI 2 480 590 4.32
Beryllium oxide BeO 2578 3.01
Beryllium sulfate BeSO 4 1127 2.5 41.3
Bismuth Bi 271.4 1564 9.79 10.05
Bismuth oxide Bi 2 O 3 825 1890 8.9
Bromine Br 2 -7.2 58.8 3.1028
Bromine chloride BrCl -66 d 5
Bromine fluoride BrF ~-33 d ~20 0.004043* gas @25°C
Bromine trifluoride BrF 3 8.77 125.8 2.803
Cadmium Cd 321.1 767 8.69 7.996
Cadmium bromide CdBr 2 568 863 5.19 4.075 115
Cadmium chloride CdCl 2 568 964 4.08 3.392 120
Cadmium carbonate CdCO 3 d 500 5.026
Cadmium fluoride CdF 2 1075 1750 6.33 4.36
Cadmium sulfide CdS ~1480 4.826
Cadmium sulfate CdSO 4 1000 4.69 76.7
Calcium Ca 842 1484 1.54 1.378
Calcium bromide CaBr 2 742 1815 3.38 3.111 156
Calcium carbonate CaCO 3 (aragonite) 450* 2.93 0.00066 20 transformation to calcite
Calcium carbonate CaCO 3 (calcite) 800 2.71 0.00066 20
Calcium chloride CaCl 2 775 1935 2.15 2.085 81.3
Calcium cyanamide CaCN 2 ~1340 sub 2.29
Calcium fluoride CaF 2 1418 2500 3.18 2.52 0.0016
Calcium hydride CaH 2 1000 1.7
Calcium hydroxide Ca(OH) 2 ~2.2 0.16 20
Calcium iodide CaI 2 783 1100 3.96 3.443 215
Calcium oxide CaO 2613 3.34
Calcium sulfate CaSO 4 1460 2.96 0.205
Carbon C(diamond) 4440* 3.513 12.4 Gpa
Carbon C(graphite) tp 4489* sub 3825 2.2 10.3 Mpa
Carbon bromide CBr 4 90 190 3.4
Carbon chloride CCl 4 -23 77 1.6 0.08
Carbon dioxide CO 2 tp -56.561 sub -78.464 1.56* solid @-79°C
Carbon disulfide CS 2 -111.7 46.2 1.2632* 20°C
Carbon fluoride CF 4 -184 -128 2.0** 0.0018* *gas @25°C  **liquid
Carbon monoxide CO -205.1 -19151 0.8495* liquid @-205.1°C
Carbon oxychloride CCl 2 O -104 8 1.4
Cesium Cs 28.5 671 1.873 1.843
Cesium chloride CsCl 646 1297 3.988 2.79 191
Chlorine Cl 2 -101.5 -34.04 1.565* liquid @-34.0°C
Chlorine dioxide ClO 2 -59 11 0.002757* gas @25°C
Chlorine fluoride ClF -155.6 -101.1 0.002226* gas @25°C
Chlorine monoxide Cl 2 O -120.6 2.2 0.003552* gas @25°C
Chlorine trifluoride ClF 3 -76.34 11.75 0.003779* gas @25°C
Chromium Cr 1907 2671 7.15 6.3
Chromium(II) chloride CrCl 2 824 1120 2.88
Chromium(III) chloride CrCl 3 827 d 1300 2.76
Chromium(III) oxide Cr 2 O 3 2432 ~3000 5.22
Chromium(IV) oxide CrO 2 d ~400 4.89
Chromium(VI) oxide CrO 3 197 d ~250 2.7 169
Cobalt Co 1495 2927 8.89 7.75
Cobalt chloride CoCl 2 737 1049 3.36 56.2
Cobalt nitrate Co(NO 3 ) 2 d 100 2.49 103
Copper Cu 1084.6 2560 8.96 7.997
Copper(I) bromide CuBr 483 1345 4.98 0.0012 20
Copper(II) bromide CuBr 2 498 900 4.71 126
Copper(I) chloride CuCl 423 1490 4.14 3.692 0.0047 20
Copper(II) chloride CuCl 2 598 993 3.4 75.7
Copper(I) cyanide CuCN 474 d 2.9
Copper(I) oxide Cu 2 O 1244 d 1800 6
Copper(II) oxide CuO 1227 6.31
Copper sulfate CuSO 4 d 560 3.6 22
Copper(I) sulfide Cu 2 S 1129 5.6
Copper(II) sulfide CuS trans 507 4.76
Fluorine F 2 -219.7 -188.1 1.5127* liquid @-188.1°C
Fluorine oxide F 2 O -223.8 -144.3 0.002207* gas @25°C
Hydrogen H 2 -259.16 -252.9 0.07083* liquid @-252.9°C
Hydrogen bromide HBr -86.8 -66.4 2.603* liquid @-84°C
Hydrogen chloride HCl -114.17 -85 1.187* liquid @-114.1°C
Hydrogen cyanide HCN -13.3 25.6 0.6876* liquid @25°C
Hydrogen fluoride HF -83.36 20 1.002* liquid @0°C
Hydrogen iodide HI -50.76 -35.55 2.85* liquid @-47°C
Hydrogen nitrate HNO 3 -41.6 83 1.5129* liquid @20°C
Hydrogen peroxide H 2 O 2 -0.43 150.2 1.44
Hydrogen selenide H 2 Se -65.73 -41.25 0.00331* gas @25°C
Hydrogen sulfide H 2 S -85.5 -59.55 0.9923* liquid @-85.5°C
Iodine I 2 113.7 184.4 4.933 0.03 20
Iodic acid HIO 3 d 110 4.63 308
Iodine bromide IBr 40 d 116 4.3
Iodine chloride ICl 27.38 d 97.0 3.24
Iodine fluoride IF d -14
Iron Fe 1538 2861 7.87 7.035
Iron(II) bromide FeBr 2 691 d 4.636 120
Iron(III) bromide FeBr 3 d 4.5 455
Iron carbide Fe 3 C 1227 7.694
Iron(II) carbonate FeCO 3 3.944 0.000062 20
Iron(II) chloride FeCl 2 677 1023 3.16 2.348 65
Iron(III) chloride FeCl 3 307.6 ~316 2.9 1.2
Iron(I) oxide FeO 1377 6
Iron(III) oxide Fe 2 O 3 1539 5.25
Iron(II,III) oxide Fe 3 O 4 1597 5.17
Iron(II) sulfide FeS 2 3.65 29.5
Lead Pb 327.46 1749 11.3 10.66
Lead(II) carbonate PbCO 3 d ~315 6.582
Lead(II) chloride PbCl 2 501 951 5.98 4.951 1.08
Lead(II) nitrate Pb(NO 3 ) 2 470 4.53 59.7
Lead(II) oxide PbO(red or litharge) 489* 9.35 transformation to massicot
Lead(II) oxide PbO(yellow or massicot) 887 9.64
Lead(IV) oxide PbO 2 d 290 9.64
Lead(II) sulfate PbSO 4 1087 6.29 0.0044
Lead(II) sulfide PbS 1113 7.6
Lithium Li 180.5 1342 0.534 0.512
Lithium bromide LiBr 550 ~1300 3.464 2.528 181
Lithium chloride LiCl 610 1383 2.07 1.02 84.5
Lithium fluoride LiF 848.2 1673 2.64 1.81 0.134
Lithium hydroxide LiOH 473 1626 1.45 12.5
Lithium iodide LiI 469 1171 4.06 3.109 165
Lithium nitrate LiNO 3 253 2.38 1.781 102
Lithium oxide Li 2 O 1438 2.013
Magnesium Mg 650 1090 1.74 1.584
Magnesium bromide MgBr 2 711 3.72 2.62 102
Magnesium chloride MgCl 2 714 1412 2.325 1.68 56
Magnesium fluoride MgF 2 1263 2227 3.148 0.013
Magnesium hydroxide Mg(OH) 2 350 2.37 0.00069 20
Magnesium oxide MgO 2825 3600 3.6
Magnesium sulfate MgSO 4 1137 2.66 35.7
Magnesium sulfide MgS 2226 2.68
Manganese Mn 1246 2061 7.3 5.85
Manganese(II) bromide MnBr 2 698 4.385 151
Manganese(II) chloride MnCl 2 650 1190 2.977 2.353 77.3
Manganese(II) oxide MnO 1842 5.37
Manganese(IV) oxide MnO 2 d 535 5.08
Mercury Hg -38.8 356.6 13.5336
Mercury (I) bromide Hg 2 Br 2 d 345 7.307
Mercury (II) bromide HgBr 2 241 318 6.05 5.126 0.61
Mercury(I) chloride Hg 2 Cl 2 tp 525 sub 383 7.16 0.0004
Mercury (II) chloride HgCl 2 277 304 5.6 4.368 7.31
Mercury (I) iodide Hg 2 I 2 290 7.7
Mercury (II) iodide HgI 2 127* / 250 354 6.3 5.222 0.006 transformation to yellow
Mercury(II) oxide HgO d 500 11.14
Mercury(I) sulfate Hg 2 SO 4 7.56 0.051
Mercury (II) sulfate HgSO 4 6.47
Mercury(II) sulfide HgS(red) 344* 8.17 tranformation to black HgS
Mercury (II) sulfide HgS(black) 820 7.7
Molybdenum Mo 2622 4639 10.2 9.33
Molybdenum(IV) oxide MoO 2 d ~1800 6.47
Molybdenum(VI) oxide MoO 3 802 1155 4.7 0.14 20
Molybdenum(IV) sulfide MoS 2 1750 5.06
Molybdenum(VI) sulf ide MoS 3 d 350
Nitrogen N 2 -210 -195.79 0.8061* liquid @-195.8°C
Nitrogen dioxide NO 2 0.003575* gas @25°C
Nitrogen oxide NO -163.6 -151.74 0.001226* gas @25°C
Nitrogen tetroxide N 2 O 4 -9.3 21.15 1.45* liquid @20°C
Nitrogen trifluoride NF 3 -206.79 -128.75 0.002902* gas @25°C
Nitrous oxide N 2 O -90.8 -88.48 0.001799* gas @25°C
Nickel Ni 1455 2913 8.9 7.81
Nickel(II) bromide NiBr 2 963 sub 5.1 131 20
Nickel(II) chloride NiCl 2 1031 sub 985 3.51 2.653 67.5
Nickel(II) fluoride NiF 2 1380 4.7 2.56
Nickel(II) hydroxide Ni(OH) 2 d 230 4.1 0.00015 20
Nickel(III) oxide Ni 2 O 3 ~600
Osmium Os 3033 5008 22.587* 20 @20°C
Osmium(VIII) oxide OsO 4 40.6 131.2 5.1 6.44 20
Oxygen O 2 -218.79 -182.96 1.141* liquid @-183.0°C
Ozone O 3 -193 -111.35 0.001962* gas @25°C
Phosphine PH 3 -133.8 -87.75 0.001390* gas @25°C
Phosphonic acid H 3 PO 4 42.4 407 1.8 548 20
Phosphorus P(black) 610 2.69
Phosphorus P(red) 579.2 sub 431 2.16
Phosphorus P(white) 44.15 280.5 1.823
Phosphorus(III) chloride PCl 5 tp 167 sub 160 2.1
Phosphorus(V) oxide P 2 O 5 562 605 2.3
Phosphorus trichloride PCl 3 -93 76 1.574
Phosphoryl chloride POCl 3 1.18 105.5 1.645
Potassium K 63.5 759 0.89 0.828
Potassium bromide KBr 734 1435 2.7467.8 2.127 25
Potassium carbonate K 2 CO 3 899 d 2.29 111
Potassium chlorate KClO 3 357 d 2.34 8.61
Potassium chloride KCl 771 1.98835.5 1.527 25
Potassium cyanide KCN 622 1.55 69.9 20
Potassium fluoride KF 858 1502 2.48 1.910 102
Potassium iodide KI 681 1323 3.12 2.448 148
Potassium manganate KMnO 4 d 2.7 7.6
Potassium nitrate KNO 3 334 d 400 2.105 1.865 38.3
Potassium nitrite KNO 2 438 e 537 1.915 312
Potassium oxide K 2 O 740 2.35
Potassium peroxide K 2 O 2 545 d
Potassium sulfate K 2 SO 4 1069 2.66 12
Rubidium Rb 39.3 688 1.53 1.46
Rubidium chloride RbCl 724 1390 2.76 2.248 93.9
Silver Ag 961.8 2162 10.5 9.32
Silver bromide AgBr 430 1502 6.47 5.577 0.000014
Silver carbonate Ag 2 CO 3 218 6.077 0.0036 20
Silver chloride AgCl 455 1547 5.56 4.83 0.00019
Silver cyanide AgCN d 320 3.95 0.0000011
Silver fluoride AgF 435 1159 5.852 172 20
Silver iodide AgI 558 1506 5.68 5.58 0.000003
Silver nitrate AgNO 3 210 d 440 4.35 3.970 234
Silver oxide Ag 2 O 827 7.2 0.0025
Silver sulfate Ag 2 SO 4 660 4.84
Silver sulfide Ag 2 S 836 7.23
Sodium Na 97.794 882.94 0.97 0.927
Sodium azide NaN 3 d 300 1.846 40.8 20
Sodium bromide NaBr 747 1390 3.2 2.342 94.6
Sodium carbonate Na 2 CO 3 856 2.54 1.972 30.7
Sodium chloride NaCl 802.02 1465 2.17 1.556 36
Sodium cyanide NaCN 562 1.6 58.2 20
Sodium fluoride NaF 996 1704 2.78 1.948 4.13
Sodium hydride NaH 638 1.39
Sodium hydroxide NaOH 323 1388 2.13 100
Sodium nitrate NaNO 3 306.5 0.261 1.90 91.2
Sodium oxide Na 2 O 1134 2.27
Sodium peroxide Na 2 O 2 675 2.805
Sodium sulfate Na 2 SO 4 884 2.7 2.069 28.1
Sodium superoxide NaO 2 284 d >320 2.17 84.8
Sulfur S(rhombic) 92.5* 444.61 2.07 transformation to monoclinic
Sulfur S(monoclinic) 115.21 444.61 2 1.819
Sulfuric acid H 2 SO 4 10.31 337 1.8305 liquid @20°C
Sulfur dioxide SO 2 -75.45 10.02 1.60* liquid @-75.5°C
Sulfur trioxide SO 3 (γ-form) 16.8 44.5 1.9
Sulfuryl chloride SO 2 Cl 2 -51 69.4 1.68
Selenium Se(gray) 220.8 685 4.809 3.99
Silicon Si 1414 3265 2.3296 2.57
Silicon carbide SiC(hexagonal) 2830 3.16
Silicon tetraboride SiB 4 d 1870 2.4
Siliane SiH 4 -185 -111.9 0.001313 gas @25°C
Tin Sn(gray) 13.2* 2586 5.769 transformation to white
Tin Sn(white) 231.9 2586 7.287 6.979
Tin(IV) chloride SnCl 4 -34.07 114.15 2.234 2.37
Tin(IV) oxide SnO 2 1630 6.85
Titanium Ti 1670 3287 4.506 4.11
Titanium(II) chloride TiCl 2 1035 1500 3.13
Titanium(III) chloride TiCl 3 d 425 960 2.64
Titanium(IV) chloride TiCl 4 -24.12 136.45 1.73 1.807
Titanium(IV) oxide TiO 2 (rutile)
1912 ~3000 4.17
Uranium U 1135 4131 19.1 17.3
Uranium (IV) fluoride UF 4 1036 1417 6.7 6.485 0.01
Uranium (VI) fluoride UF 6 tp 64.06 sub 56.5 5.09
Uranium (IV) oxide UO 2 2847 10.97
Vanadium V 1910 3407 6 5.5
Vanadium(III) chloride VCl 3 d 500 3
Vanadium(IV) chloride VCl 4 -28 151 1.816
Vanadium(V) oxide V 2 O 5 681 1750 3.35 0.07
Water H 2 O 0.00 99.974 0.9970
Zinc Zn 419.5 907 7.134 6.57
Zinc bromide ZnBr 2 402 ~670 4.5 3.47 488
Zinc chloride ZnCl 2 325 732 2.907 2.54 408
Zinc fluoride ZnF 2 872 1500 4.9 1.55
Zinc iodide ZnI 2 450 625 4.74 3.878 438
Zinc oxide ZnO 1974 5.6
Zinc nitrate Zn(NO 3 ) 2 d
Zinc sulfate ZnSO 4 d 680 3.8 3.14 57.7
Zinc sulfide ZnS(sphalerite) 1020* 4.04 transformation to wurtzite
Zinc sulfide ZnS(wurtzite) 1827 sub 4.09
Zirconium Zr 1854 4406 6.52 5.8
Zirconium(II) chloride ZrCl 2 722 3.16
Zirconium(IV) chloride ZrCl 4 tp 437 sub 331 2.8 1.643
1) : Solubility at 25°C unless other temperature in °C is indicated with superscript,     * : comment is given in the last column
d : decomposes,    e : explodes,     tp : triple point,       sub : sublimates (solid to gas)
Boiling Points
Densities
Fluid Mechanics
Material Properties
Melting and Freezing Points
Density Converter
Hydrocarbons - Physical Data
Hydrocarbons - Melting Point vs. Molecular Weight
Calculate melting point of hydrocarbons from molecular weight (molar mass).
Inorganic Acids and Bases - pKa Values
Values for the negative logarithm of the acid dissociation constant, pKa, of inorganic acids and bases, as well as hydrated metal ions.
Liquid-Liquid Solution - Shrinkage and Estimation of Density
It is possible to estimate the density of a liquid-liquid solution from the density of the solute and the solvent. However, due to shrinkage, the estimate will be a bit too low.
Liquids - Freezing and Melting Points
Common fluids and their freezing and melting points.
Melting and Boiling Temperatures - Evaporation and Melting Heats common Materials
Melting and boiling point temperatures, latent heat of evaporation, and melting heat of common substances like copper, gold, lead and more - SI units.
Metals - Specific Heats
Naming Inorganic Binary Compounds
Rules for naming inorganic ionic and covalent types of chemical compounds.
Organic Nitrogen Compounds - Physical Data
Boiling and melting points of amines, diamines, pyrroles, pyridines, piperidines and quinolines shown together with their molecular structures, as well as molweights and density.
Organic Sulfur Compounds - Physical Data
Boiling and melting points of thoils, sulfides, disulfides and thiophenes shown together with molecular structures, as well as molweights and density.
Physical Constants
Physical constants - SI Units.
Solubility
The amount of a solute that can be dissolved in a solvent.
Standard State and Enthalpy of Formation, Gibbs Free Energy of Formation, Entropy and Heat Capacity
Definition and explanation of the terms standard state and standard enthalpy of formation, with listing of values for standard enthalpy and Gibbs free energy of formation, as well as standard entropy and molar heat capacity, of 370 inorganic compounds.
Sugar Solubility in Water
Solubility of sugar in water.
Thermodynamic Terms - Functions and Relations
