Physical Constants
Physical Constants
DescriptionSymbolFormulaValue1Unit1Value2Unit2
Absolute zero, temperature 0 K -273.15 oC
Acceleration of gravity at earth's surface g 9.81 m/s2 32.2 ft/s2
Atmospheric pressure at sea level 1.01325×105 N/m2 14.69 lb/in2
Atomic mass unit 1.660540×10-27 kg 1.000 u
Avogadro's constant NA 6.022141×1023 mol-1
Base of natural logaritms e 2.718 281 828...
Base of natural logaritms lnx 2.3026 log(x)
Bohr magneton μB e h/4πme 9.274009994×10-24 Am2 5.788381×10-5 eV/T
Bohr radius a0 ε0h2/π mee2 5.2917721067×10-11 m 2.08×10-9 in
Boltzmann constant k R/NA 1.38064852×10-23 J/K 8.617330×10-5 eV/K
Charge of electron e 1.602176×10-19 C
Faraday constant F e NA 9.648533289×104 C/mol 26.801 Ah/mol
Fine structure constant α 7.29720×10-3
Gas constant (molar, ideal) R 8.3144598 J/molK 82.057338 cm3atm/molK
Gravitational constant G 6.67408×10-11 m3/kg s2
Mass of electron (rest mass) me 9.10938356×10-31 kg 5.485799×10-4 u
Mass of neutron mn 1.67492747×10-27 kg 1.008664915 u
Mass of proton mp 1.67262190×10-27 kg 1.007276466 u
Permeability of a vacuum μ0 4p×10-7 kg m/s2A2
Permittivity of a vacuum ε0 1/μ0 c02 8.854187817×10-12 C2/Nm2 A2s4/kg m3
Planck's constant h 6.626070040×10-34 J s 4.135667×10-15 eV s
Radiation constant, first C1 2 π h c2 3.741844×10-16 Wm2
Radiation constant, second C2 h c/k 1.438833×10-2 mK
Ratio of a circle's circumference(C) to its diameter π C/d 3.141592653…
Rydberg constant R∞ mee4/8ε02h3c0 1.097373156×107 m-1
Speed of light in vacuum c0 2.99792458×108 m/s
Stefan-Boltzmann constant σ 5.670367×10-8 W/m2K4 11.7×10-8 cal/cm2dayK4
Volume ideal gas, 1 atm, 0°C Vm 22413.6 cm3/mol 22.4136 liter/mol
Volume ideal gas,1 atm, 25°C Vm 24466.1 cm3/mol 1.0244651 m3/mol
Basics
Constants of π
The mathematical π constants.
Constants of e
The mathematical e constants.
Materials - Light Reflecting Factors
Light reflecting factor materials.
Numerical Constants
Some numerical constants.
Refractive Index common Liquids, Solids and Gases
Some common liquids, solids, and gases and their refractive indexes.
Solar System Constants
Properties and data for the Sun, the Earth and the Moon.
