Thermodynamic Terms - Functions and Relations
- Chemical energy - is related to the relationships between molecules in chemical compounds. When chemicals react with each other, they may give off heat (exothermic reaction) or require heat (endothermic reaction)
- Electric energy - is related to electrons moving through a conductor
- Energy - can be reduced to the concepts of heat and work and can be found in various forms: potential energy, kinetic energy, thermal or internal energy, chemical energy, and nuclear energy
- Enthalpy - is a term with energy units that combines internal energy with a pressure/volume or flow work term
- Entropy - is a property of matter that measures the degree of randomization or disorder. The natural state is for entropy to be produced by all processes
- Heat - is energy in motion from one region to an other as a result of temperature difference
- Internal energy - has to do with activity within the molecular structure and is typically observed with temperature measurement
- Kinetic energy - is the energy of motion and is proportional to the square of the velocity as well to the mass of the moving body
- Nuclear energy - is related to the energy of atomic relationships between the fundamental particles. Nuclear fission and fusion are reactions which release nuclear energy
- Potential energy - is the energy of location or position of a mass in a force field
- Property - is a measurable characteristic of a system or substance. Temperature, density, pressure etc
- Specific Heat - The specific heat is the amount of heat required to change a unit mass (or unit quantity, such as mole) of a substance by one degree in temperature
- Temperature - is a term used to quantify the difference between warm and cold level of internal energy of a substance
- Work - is an energy form which can be equated to the rising of a weight as moving a mass in a force field or moving a liquid against a resisting force
See also Symbols Used to Denote a Chemical Reaction, Process or Condition
| Term | Function |
| Activity coefficient | γi = fi/(xifiθ) |
| Chemical potential | μi = (∂G/∂ni)T,p,nj≠i |
| Energy | U |
| Enthalpy | H = U + pV |
| Entropy | S |
| Fugasity | fi = (xi)exp{(μi - μiÞg)/RT} |
| Gibbs (free) energy | G = U + pV - TS |
| Gibbs-Duhem relation | 0 = SdT - Vdp + Σinidμi |
| Gibbs-Helmholtz equation | H = G - T(∂G/∂T)p |
| Helmholtz energy | A = U - TS |
| Isentropic (constant heat and mass) compressibility | κS = - (∂V/∂p)S/V |
| Isothermal (constant temperature) compressibility | κT = - (∂V/∂p)T/V |
| κT - κS = T αV2V/Cp |
| Isobaric (constant pressure) expansivity | αV= (∂V/∂T)p/V |
| Isobaric heat capacity | Cp = (∂H/∂T)p |
| Isochoric (constant volume) heat capacity | CV = (∂U/∂T)v |
| Cp - CV = Tα2V/κT | |
| Joule-Thompson expansion | μJT = (∂T/∂p)H = - {V - (∂V/∂T)p}/Cp |
| ΦJT = (∂H/∂p)T = V - T(∂V/∂T)p |
| Maxwell relations | (∂S/∂p)T = - (∂V/∂p)p |
| (∂S/∂V)T = - (∂p/∂T)V | |
| Partial molar quantity | Xi = (∂X/∂ni)T,p,nj≠i |
| Perfect (ideal) gas (symbol Þg) | pV = (Σini)RT |
| μiÞg = μiθ + RTln(xip/pθ) |
Where
p = pressure
V = Volume
T = temperature
ni = amount of substance i
xi = ni/Σjnj = mole fraction of substance i
R = gas constant
• Thermodynamics
1st Law of Thermodynamics
2nd Law of Thermodynamics
Entropy and disorder.
Combustion Heat
Dimensionless Numbers
Physical and chemical dimensionless quantities - Reynolds number, Euler, Nusselt, and Prandtl number - and many more.
Heat Capacity
Individual & Universal Gas Constants: Definitions, Values, and Applications
Property vs. State
The concept of properties and state.
Symbols Used to Denote a Chemical Reactions and Process or Condition
Explanation of symbols used as subscripts or superscripts to tell more about the type of chemical reaction, process or condition.
Third Law of Thermodynamics
The entropy of a substance is zero if the absolute temperature is zero.
WABT - Weighted Average Bed Temperature
Definition and examples of calculation of weighted average bed temperature in adiabatic reactors.
