Liquids - Latent Heat of Evaporation
The input energy required to change the state from liquid to vapor at constant temperature is called the latent heat of vaporization. When a liquid vaporize at the normal boiling point the temperature of the liquid will not rise beyond the temperature of the boiling point.
The latent heat of vaporization is the amount of
"heat required to convert a unit mass of a liquid into vapor without a change in temperature".
| Product | Latent Heat of Evaporation*) - he - | |
| (kJ/kg) | (Btu/lb) | |
| Acetic acid | 402 | 173 |
| Acetone | 518 | 223 |
| Alcohol | 896 | 385 |
| Alcohol, ethyl (ethanol) | 846 | 364 |
| Alcohol, methyl (methanol alcohol, wood alcohol, wood naphtha or wood spirits) | 1100 | 473 |
| Alcohol, propyl | 779 | 335 |
| Ammonia | 1369 | 589 |
| Aniline | 450 | 193 |
| Benzene | 390 | 168 |
| Bromine | 193 | 83 |
| Carbon bisulphide | 160 | |
| Carbon dioxide | 574 | 247 |
| Carbon disulphide | 351 | 151 |
| Carbon tetrachloride | 194 | 83 |
| Chlorine | 293 | |
| Chloroform | 247 | 106 |
| Decane | 263 | 113 |
| Dodecane | 256 | 110 |
| Ether | 377 | 162 |
| Ethylene glycol | 800 | 344 |
| Trichlorofluoromethane refrigerant R-11 | 180 | 77 |
| Dichlorodifluoromethane refrigerant R-12 | 165 | 71 |
| Chlorodifluoromethane refrigerant R-22 | 232 | 100 |
| Glycerine | 974 | 419 |
| Helium | 21 | 9 |
| Heptane | 318 | 137 |
| Hexane | 365 | 157 |
| Hydrogen | 461 | 198 |
| Iodine | 164 | 71 |
| Kerosene | 251 | 108 |
| Mercury | 295 | 127 |
| Methyl chloride | 406 | |
| Nitrogen | 199 | 86 |
| Octane | 298 | 128 |
| Oxygen | 214 | 92 |
| Propane | 428 | 184 |
| Propylene | 342 | 147 |
| Propylene glycol | 914 | 393 |
| Sulphur | 1510 | 650 |
| Sulfur dioxide | 164 | |
| Toluene | 351 | 151 |
| Turpentine | 293 | 126 |
| Water | 2256 | 970.4 |
- 1 kJ/kg = 0.43 Btu/lbm = 0.24 kcal/kg
*) The latent heats of evaporation are based on fluid boiling point temperatures at atmospheric pressure.
Evaporation Heat
The heat required to evaporate a fluid can be calculated as:
q = he m (1)
q = evaporation heat (kJ, Btu)
he = evaporation heat (kJ/kg, Btu/lb)
m = mass of liquid (kg, lb)
Example - Calculate heat required to evaporate 10 kg of water
The latent heat of evaporation for water is 2256 kJ/kg at atmospheric pressure and 100 oC. The heat required to evaporate 10 kg can be calculated as
q = (2256 kJ/kg) (10 kg)
= 22560 kJ
Acetone - Density and Specific Weight
Online calculator, figures and tables showing density and specific weight of acetone at temperatures ranging from -95 to 275 °C (-138 to 530 °F) at atmospheric and higher pressure - Imperial and SI Units.
Evaporation of water from a water surface - like a swimming pool or an open tank - depends on water temperature, air temperature, air humidity and air velocity above the water surface - online calculator.
Evaporative Cooling
Evaporative cooling tutorial.
Latent Heat Flow
Melting and Boiling Temperatures - Evaporation and Melting Heats common Materials
Melting and boiling point temperatures, latent heat of evaporation, and melting heat of common substances like copper, gold, lead and more - SI units.
Methanol - Thermophysical Properties vs. Temperature
Thermophysical properties of methanol.
Nitrogen (N₂) Density & Specific Weight: Temperature & Pressure Data and Calculator
Online calculator, figures and tables showing density and specific weight of nitrogen, N2, at temperatures ranging from -175 to 1325 °C (-280 to 2400 °F) at atmospheric and higher pressure - Imperial and SI Units.
Steam and Vapor Enthalpy
Vapor and steam enthalpy, specific enthalpy of saturated liquid, saturated vapor and superheated vapor.
Toluene Liquid - Thermal Properties vs. Temperature
Density, specific heat, thermal conductivity and more.
