Water Properties: Vaporization Heat vs. Temperature - Charts and Calculator
The (latent) heat of vaporization (∆Hvap ) also known as the enthalpy of vaporization or evaporation, is the amount of energy (enthalpy) that must be added to a liquid substance, to transform a given quantity of the substance into a gas .
The enthalpy of vaporization is a function of the pressure at which that transformation takes place. The heat of vaporization diminishes with increasing temperature and it vanishes completely at a certain point called the critical temperature (Critical temperature for water: 373.946 °C or 705.103 °F, Critical pressure: 220.6 bar = 22.06 MPa = 3200 psi).
Online Water Heat of Vaporization Calculator
The calculator below can be used to calculate the liquid water heat of vaporization at vapor pressure at given temperatures.
The output heat is given as kJ/mol, kJ/kg, kWh/kg, cal/g, Btu(IT)/mol and Btu(IT)/lbm.
Note! Temperature must be within the ranges 0-370 °C, 32-700 °F, 273-645 K and 492-1160 °R to get valid values.
For vapor pressure - check tables below.
See Water and Heavy Water - for thermodynamic properties.
See also Water Boiling points at high pressure, Boiling points at vacuum pressure, Density, specific weight and thermal expansion coefficient, Dynamic and kinematic viscosity, Enthalpy and entropy, Ionization Constant, pKw , of normal and heavy water, Melting points at high pressure, Saturation pressure, Specific gravity, Specific heat (heat capacity) and Specific volume for online calculatores, and similar figures and tables as shown below.
Heat of vaporization for liquid water at saturation pressure at temperatures from 0 to 374 °C:
Temperature | Vapor pressure | Heat of vaporization, ∆Hvap | |||
(°C) | (kPa) (100*bar) |
(J/mol) | (kJ/kg) | (Wh/kg) | (Btu(IT)/lbm ) |
0.01 | 0.61165 | 45054 | 2500.9 | 694.69 | 1075.2 |
2 | 0.70599 | 44970 | 2496.2 | 693.39 | 1073.2 |
4 | 0.81355 | 44883 | 2491.4 | 692.06 | 1071.1 |
10 | 1.2282 | 44627 | 2477.2 | 688.11 | 1065.0 |
14 | 1.5990 | 44456 | 2467.7 | 685.47 | 1060.9 |
18 | 2.0647 | 44287 | 2458.3 | 682.86 | 1056.9 |
20 | 2.3393 | 44200 | 2453.5 | 681.53 | 1054.8 |
25 | 3.1699 | 43988 | 2441.7 | 678.25 | 1049.7 |
30 | 4.2470 | 43774 | 2429.8 | 674.94 | 1044.6 |
34 | 5.3251 | 43602 | 2420.3 | 672.31 | 1040.5 |
40 | 7.3849 | 43345 | 2406.0 | 668.33 | 1034.4 |
44 | 9.1124 | 43172 | 2396.4 | 665.67 | 1030.3 |
50 | 12.352 | 42911 | 2381.9 | 661.64 | 1024.0 |
54 | 15.022 | 42738 | 2372.3 | 658.97 | 1019.9 |
60 | 19.946 | 42475 | 2357.7 | 654.92 | 1013.6 |
70 | 31.201 | 42030 | 2333.0 | 648.06 | 1003.0 |
80 | 47.414 | 41579 | 2308.0 | 641.11 | 992.26 |
90 | 70.182 | 41120 | 2282.5 | 634.03 | 981.30 |
96 | 87.771 | 40839 | 2266.9 | 629.69 | 974.59 |
100 | 101.42 | 40650 | 2256.4 | 626.78 | 970.08 |
110 | 143.38 | 40167 | 2229.6 | 619.33 | 958.56 |
120 | 198.67 | 39671 | 2202.1 | 611.69 | 946.73 |
140 | 361.54 | 38630 | 2144.3 | 595.64 | 921.88 |
160 | 618.23 | 37508 | 2082.0 | 578.33 | 895.10 |
180 | 1002.8 | 36286 | 2014.2 | 559.50 | 865.95 |
200 | 1554.9 | 34944 | 1939.7 | 538.81 | 833.92 |
220 | 2319.6 | 33462 | 1857.4 | 515.94 | 798.54 |
240 | 3346.9 | 31804 | 1765.4 | 490.39 | 758.99 |
260 | 4692.3 | 29934 | 1661.6 | 461.56 | 714.36 |
280 | 6416.6 | 27798 | 1543.0 | 428.61 | 663.37 |
300 | 8587.9 | 25304 | 1404.6 | 390.17 | 603.87 |
320 | 11284 | 22310 | 1238.4 | 344.00 | 532.42 |
340 | 14601 | 18507 | 1027.3 | 285.36 | 441.66 |
360 | 18666 | 12967 | 719.8 | 199.9 | 309.5 |
373.946 | 22064 | 0 | 0.0 | 0.0 | 0.0 |
Heat of vaporization for liquid water at saturation pressure at temperatures from 0 to 705 °F:
(°F) | (psi) | (Btu(IT)/mol) | (Btu(IT)/lbm ) | (cal/g) | (kJ/kg) |
32.2 | 0.0891 | 42.70 | 1075.2 | 597.33 | 2500.9 |
40 | 0.1219 | 42.52 | 1070.7 | 594.82 | 2490.4 |
50 | 0.1783 | 42.30 | 1065.0 | 591.67 | 2477.2 |
60 | 0.2564 | 42.07 | 1059.4 | 588.54 | 2464.1 |
70 | 0.3632 | 41.85 | 1053.7 | 585.39 | 2450.9 |
80 | 0.5073 | 41.62 | 1048.0 | 582.25 | 2437.7 |
90 | 0.6990 | 41.40 | 1042.4 | 579.09 | 2424.5 |
100 | 0.9506 | 41.17 | 1036.7 | 575.92 | 2411.3 |
110 | 1.277 | 40.95 | 1030.9 | 572.74 | 2398.0 |
120 | 1.695 | 40.72 | 1025.2 | 569.55 | 2384.6 |
130 | 2.226 | 40.49 | 1019.4 | 566.34 | 2371.2 |
140 | 2.893 | 40.26 | 1013.6 | 563.13 | 2357.7 |
150 | 3.723 | 40.02 | 1007.7 | 559.86 | 2344.0 |
160 | 4.747 | 39.79 | 1001.8 | 556.58 | 2330.3 |
170 | 6.000 | 39.55 | 995.87 | 553.26 | 2316.4 |
180 | 7.519 | 39.31 | 989.85 | 549.92 | 2302.4 |
190 | 9.350 | 39.07 | 983.76 | 546.54 | 2288.2 |
200 | 11.54 | 38.83 | 977.60 | 543.11 | 2273.9 |
210 | 14.14 | 38.58 | 971.35 | 539.64 | 2259.4 |
212 | 14.71 | 38.53 | 970.08 | 538.93 | 2256.4 |
220 | 17.20 | 38.33 | 965.02 | 536.12 | 2244.6 |
240 | 24.99 | 37.81 | 952.05 | 528.92 | 2214.5 |
260 | 35.45 | 37.28 | 938.64 | 521.46 | 2183.3 |
280 | 49.22 | 36.73 | 924.71 | 513.73 | 2150.9 |
300 | 66.6 | 36.15 | 910.21 | 505.67 | 2117.1 |
350 | 135 | 34.59 | 870.97 | 483.87 | 2025.9 |
400 | 247 | 32.82 | 826.41 | 459.12 | 1922.2 |
450 | 422 | 30.78 | 774.93 | 430.51 | 1802.5 |
500 | 680 | 28.37 | 714.36 | 396.87 | 1661.6 |
550 | 1044 | 25.48 | 641.56 | 356.42 | 1492.3 |
600 | 1541 | 21.93 | 552.09 | 306.72 | 1284.2 |
625 | 1849 | 19.41 | 488.64 | 271.46 | 1136.6 |
650 | 2205 | 16.95 | 426.81 | 237.11 | 992.8 |
675 | 2615 | 13.47 | 339.22 | 188.46 | 789.0 |
705.103 | 3196 | 0.00 | 0.00 | 0.00 | 0.0 |
• Boiling Points of Fluids
• Steam and Condensate
• Thermodynamics
• Thermodynamics
• Water Systems
Compressed Water - Properties vs. Temperature
Specific volume, enthalpy and entropy of compressed water.
Seawater - Properties
Seawater properties like density, saturation pressure, specific heat, electrical conductivity and absolute viscosity.
Supercooled Water - Vapor Pressure vs. Temperature
Undercooled water and vapor pressure.
Water - Dynamic and Kinematic Viscosity at Various Temperatures and Pressures
Water - Properties vs. Temperature and Pressure
Liquid water properties at temperatures between melting point and boiling point and pressures of 14.7 psia, 1000 psia and 10000 psia (1 atm, 68.1atm and 681 atm).
Water Vapor Saturation Pressure: Data, Tables & Calculator
