The boiling point of a substance is the temperature at which the vapor pressure of the liquid equals the pressure surrounding the liquid, and the liquid changes into a vapor. The boiling point of a liquid varies depending upon the surrounding pressure.
A liquid in a partial vacuum has a lower boiling point than when that liquid is at atmospheric pressure.
Online Water Boiling Point Calculator
The calculator below can be used to calculate the water boiling point at given, absolute pressures.
The output temperature is given as °C, °F, K and °R.
Note! ranges 0-1000 mbara, 0-14.7 psia, 0-760 mm Hg or 0-30 in Hg.
Choose the actual unit of pressure:
Below, figures and tables show the boiling point of water at varying vacuum .
See also other properties of Water at varying temperature and pressure : Boiling points at high pressure, Density and specific weight, Dynamic and kinematic viscosity, Enthalpy and entropy, Heat of vaporization, Ionization Constant, pKw , of normal and heavy water, Melting points at high pressure, Prandtl number, Properties at Gas-Liquid Equilibrium Conditions, Saturation pressure, Specific gravity, Specific heat (heat capacity), Specific volume, Thermal conductivity, Thermal diffusivity and Vapour pressure at gas-liquid equilibrium.
Boiling point as function of the pressure, given as "mm Hg below standard atmospheric pressure":
(= Vacuum of e.g. 100 mm Hg is the same as (760-100)=660 mm Hg absolute pressure)
The table shows the water boiling temperature at different vacuum pressure.
Vacuum is given as absolute pressure and pressure "below standard atmospheric pressure" (1 bara = 0 vacuum):
For full table with Vacuum and Water Boiling Point - rotate the screen!
| Absolute pressure | Vacuum (below standard atmospheric pressure) | Water boiling point | ||||||
| (Microns) (μm Hg) | (in Hg) | (psia) | (mbara) (100*Pa) | (in Hg) | (mmHg) (Torr) | (mbar) (100*Pa) | (°C) | (°F) |
| 760000 | 29.92 | 14.696 | 1013.3 | 0 | 0 | 0 | 100 | 212 |
| 635000 | 25.00 | 12.279 | 846.6 | 4.92 | 125.0 | 167 | 96 | 205 |
| 525526 | 20.69 | 10.162 | 700.6 | 9.23 | 234.4 | 313 | 90 | 194 |
| 500000 | 19.69 | 9.668 | 666.6 | 10.24 | 260.1 | 347 | 89 | 192 |
| 355092 | 13.98 | 6.866 | 473.4 | 15.94 | 404.9 | 540 | 80 | 176 |
| 233680 | 9.200 | 4.519 | 311.5 | 20.72 | 526.3 | 702 | 70 | 158 |
| 200000 | 7.874 | 3.867 | 266.6 | 22.05 | 560.1 | 747 | 67 | 152 |
| 149352 | 5.880 | 2.888 | 199.1 | 24.04 | 610.6 | 814 | 60 | 140 |
| 100000 | 3.937 | 1.934 | 133.3 | 25.98 | 659.9 | 880 | 52 | 125 |
| 92456 | 3.640 | 1.788 | 123.3 | 26.28 | 667.5 | 890 | 50 | 122 |
| 55118 | 2.170 | 1.066 | 73.48 | 27.75 | 704.9 | 940 | 40 | 104 |
| 31750 | 1.250 | 0.614 | 42.33 | 28.67 | 728.2 | 971 | 30 | 86 |
| 25400 | 1.000 | 0.491 | 33.86 | 28.92 | 734.6 | 979 | 27 | 80 |
| 22860 | 0.900 | 0.442 | 30.48 | 29.02 | 737.1 | 983 | 24 | 76 |
| 20320 | 0.800 | 0.393 | 27.09 | 29.12 | 739.6 | 986 | 22 | 72 |
| 17780 | 0.700 | 0.344 | 23.71 | 29.22 | 742.2 | 990 | 21 | 69 |
| 15240 | 0.600 | 0.295 | 20.32 | 29.32 | 744.7 | 993 | 18 | 64 |
| 12700 | 0.500 | 0.246 | 16.93 | 29.42 | 747.3 | 996 | 15 | 59 |
| 10160 | 0.400 | 0.196 | 13.55 | 29.52 | 749.8 | 1000 | 12 | 53 |
| 7620 | 0.300 | 0.147 | 10.16 | 29.62 | 752.3 | 1003 | 7 | 45 |
| 4572 | 0.180 | 0.088 | 6.10 | 29.74 | 755.4 | 1007 | 0 | 32 |
| 2540 | 0.100 | 0.049 | 3.39 | 29.82 | 757.4 | 1009.82 | -6 | 21 |
| 1270 | 0.050 | 0.025 | 1.69 | 29.87 | 758.7 | 1011.51 | -14 | 6 |
| 1000 | 0.039 | 0.019 | 1.33 | 29.88 | 759.0 | 1011.85 | -17 | 1 |
| 500 | 0.020 | 0.0097 | 0.67 | 29.90 | 759.5 | 1012.53 | -24 | -12 |
| 300 | 0.012 | 0.0058 | 0.40 | 29.91 | 759.7 | 1012.87 | -29 | -21 |
| 254 | 0.010 | 0.0049 | 0.34 | 29.91 | 759.7 | 1012.87 | -31 | -24 |
| 127 | 0.005 | 0.0025 | 0.17 | 29.92 | 759.8 | 1013.04 | -37 | -35 |
| 100 | 0.0039 | 0.0019 | 0.13 | 29.92 | 760.0 | 1013.21 | -40 | -40 |
| 50 | 0.0020 | 0.0010 | 0.07 | 29.92 | 760.0 | 1013.21 | -46 | -50 |
| 25.4 | 0.0010 | 0.0005 | 0.03 | 29.919 | 759.9 | 1013.17 | -51 | -60 |
| 12.7 | 0.0005 | 0.00025 | 0.017 | 29.9195 | 760.0 | 1013.19 | -57 | -70 |
| 2.54 | 0.0001 | 0.00005 | 0.003 | 29.9199 | 760.0 | 1013.20 | -68 | -90 |
- 0% vacuum = 760 torr = 14.7 psia = 29.92 in mercury abs = 101.4 kPa abs
- 50% vacuum = 380 torr = 7.3 psia = 15 in mercury abs = 50.8 kPa abs
- 99.9% vacuum = 1 torr = 0.01934 psia = 0.03937 in mercury abs = 1.3 kPa abs
• Boiling Points of Fluids
• Steam and Condensate
• Thermodynamics
• Thermodynamics
• Water Systems
Air - SCFM versus ACFM and ICFM
Actual air compressor capacity (ACFM) vs. standard air capacity (SCFM) and inlet air capacity (ICFM).
Feed Pumps in Steam Systems - Suction Lift Head vs. Temperature
Cavitation of impellers increases with water temperatures.
Moist Air - Water Vapor and Saturation Pressure
Saturation pressure of water vapor in moist air vs. temperature.
Vacuum
Vacuum is defined as air pressure below atmospheric pressure.
Vacuum - Air Expansion Ratio
Convert vacuum air volume to standard air volume
Vacuum - Evacuation Time
Vacuum pumps - calculate flow rate and required evacuation time.
Vacuum - Pressure Units Converter
Converting between vacuum units like % vacuum - mm Mercury - psi - torr - micron - kPa.
Vacuum Pipes - Flow Velocities
Air velocity diagrams for vacuum pipe lines.
Vacuum Pipes - Pressure Loss vs. Air Flow
Calculate pressure drops in vacuum pipe lines.
Vacuum Pumps - Exhaust Pipe Capacities
Capacities of vacuum pump exhaust pipes.
Water - Dynamic and Kinematic Viscosity at Various Temperatures and Pressures
Ionization constant (= dissociation constant = self-ionization constant = ion product = autoprotolysis constant ) of water and heavy water, given as function of temperature (°C and °F) in figures and tables.
Water - Saturation Pressure and Specific Weight vs. Temperature
Vapor pressure and specific weight of water at temperatures ranging 32 to 212 oF - Imperial Units.
Water Vapor Saturation Pressure: Data, Tables & Calculator
