Vacuum Pipes - Flow Velocities
Air velocities in vacuum pipes can be estimated with the diagrams below.
Standard and Actual Air Volume - cfm
Download and print Vacuum Pipe Line - Velocity vs. Fow Chart
The diagram is calculated for steel pipes schedule 40.
Example - Estimating the Vacuum Air Flow Velocity
Velocity in a NPS 3" steel pipe with standard air volume flow 100 scfm at 30% vacuum can be estimated to approximately 3000 fpm as indicated in the diagram below:
Standard and Actual Air Volume - l/s
Gases and Compressed Air
Vacuum
Vacuum is defined as air pressure below atmospheric pressure.
Vacuum - Air Expansion Ratio
Convert vacuum air volume to standard air volume
Vacuum - Evacuation Time
Vacuum pumps - calculate flow rate and required evacuation time.
Vacuum - Flow Measurement
Measure air volume flow in vacuum.
Vacuum - Pressure Units Converter
Converting between vacuum units like % vacuum - mm Mercury - psi - torr - micron - kPa.
Vacuum Pipes - Pressure Loss vs. Air Flow
Calculate pressure drops in vacuum pipe lines.
