Vacuum - Flow Measurement
For standard or normal pressure it is common to measure flow in
- standard cubic feet minute - scfm - imperial units
- normal metric liter per second - nl/s - metric units
In vacuum the air or gas is expanded and it is common to use
- actual cubic feet minute - acfm - imperial units
- actual metric liter per second - al/s - metric units
Since the gas is expanded, actual volume flow is greater than standard volume flow for the same amount of gas.
The flow volume can be converted from standard volume flow to actual volume flow by the expression:
qa = qs (29.92 / p) ((t + 460) / 520) (1)
qa= actual volume flow (acfm)
qs= standard volume flow (scfm)
p= actual pressure (in Hg)
t= temperature (oF)
Pressure | Conversion Factor from scfm to acfm (or nl/s to al/s) | |||||||
Temperature(oF) | ||||||||
in Hg absolute | in Hg gauge | kPa absolute | 0 | 30 | 60 | 90 | 120 | 150 |
29.92 | 0.00 | 101.42 | 0.88 | 0.94 | 1.00 | 1.06 | 1.12 | 1.17 |
28.92 | 1.00 | 98.03 | 0.92 | 0.97 | 1.03 | 1.09 | 1.15 | 1.21 |
27.92 | 2.00 | 94.64 | 0.95 | 1.01 | 1.07 | 1.13 | 1.20 | 1.26 |
26.92 | 3.00 | 91.25 | 0.98 | 1.05 | 1.11 | 1.18 | 1.24 | 1.30 |
25.92 | 4.00 | 87.86 | 1.02 | 1.09 | 1.15 | 1.22 | 1.29 | 1.35 |
24.92 | 5.00 | 84.47 | 1.06 | 1.13 | 1.20 | 1.27 | 1.34 | 1.41 |
23.92 | 6.00 | 81.08 | 1.11 | 1.18 | 1.25 | 1.32 | 1.40 | 1.47 |
22.92 | 7.00 | 77.69 | 1.15 | 1.23 | 1.31 | 1.38 | 1.46 | 1.53 |
21.92 | 8.00 | 74.31 | 1.21 | 1.29 | 1.36 | 1.44 | 1.52 | 1.60 |
20.92 | 9.00 | 70.92 | 1.27 | 1.35 | 1.43 | 1.51 | 1.60 | 1.68 |
19.92 | 10.00 | 67.53 | 1.33 | 1.42 | 1.50 | 1.59 | 1.68 | 1.76 |
18.92 | 11.00 | 64.14 | 1.40 | 1.49 | 1.58 | 1.67 | 1.76 | 1.86 |
17.92 | 12.00 | 60.75 | 1.48 | 1.57 | 1.67 | 1.77 | 1.86 | 1.96 |
16.92 | 13.00 | 57.36 | 1.56 | 1.67 | 1.77 | 1.87 | 1.97 | 2.07 |
15.92 | 14.00 | 53.97 | 1.66 | 1.77 | 1.88 | 1.99 | 2.10 | 2.20 |
14.92 | 15.00 | 50.58 | 1.77 | 1.89 | 2.01 | 2.12 | 2.24 | 2.35 |
13.92 | 16.00 | 47.19 | 1.90 | 2.03 | 2.15 | 2.27 | 2.40 | 2.52 |
12.92 | 17.00 | 43.80 | 2.05 | 2.18 | 2.32 | 2.45 | 2.58 | 2.72 |
11.92 | 18.00 | 40.41 | 2.22 | 2.37 | 2.51 | 2.65 | 2.80 | 2.94 |
10.92 | 19.00 | 37.02 | 2.42 | 2.58 | 2.74 | 2.90 | 3.06 | 3.21 |
9.92 | 20.00 | 33.63 | 2.67 | 2.84 | 3.02 | 3.19 | 3.36 | 3.54 |
8.92 | 21.00 | 30.24 | 2.97 | 3.16 | 3.35 | 3.55 | 3.74 | 3.93 |
7.92 | 22.00 | 26.85 | 3.34 | 3.56 | 3.78 | 4.00 | 4.21 | 4.43 |
6.92 | 23.00 | 23.46 | 3.82 | 4.07 | 4.32 | 4.57 | 4.82 | 5.07 |
5.92 | 24.00 | 20.07 | 4.47 | 4.76 | 5.05 | 5.35 | 5.64 | 5.93 |
4.92 | 25.00 | 16.68 | 5.38 | 5.73 | 6.08 | 6.43 | 6.78 | 7.13 |
3.92 | 26.00 | 13.29 | 6.75 | 7.19 | 7.63 | 8.07 | 8.51 | 8.95 |
2.92 | 27.00 | 9.90 | 9.06 | 9.66 | 10.25 | 10.84 | 11.43 | 12.02 |
1.92 | 28.00 | 6.51 | 13.79 | 14.68 | 15.58 | 16.48 | 17.38 | 18.28 |
0.92 | 29.00 | 3.12 | 28.77 | 30.65 | 32.52 | 34.40 | 36.27 | 38.15 |
0.82 | 29.10 | 2.78 | 32.28 | 34.38 | 36.49 | 38.59 | 40.70 | 42.80 |
0.72 | 29.20 | 2.44 | 36.76 | 39.16 | 41.56 | 43.95 | 46.35 | 48.75 |
0.62 | 29.30 | 2.10 | 42.69 | 45.47 | 48.26 | 51.04 | 53.83 | 56.61 |
0.52 | 29.40 | 1.76 | 50.90 | 54.22 | 57.54 | 60.86 | 64.18 | 67.50 |
0.42 | 29.50 | 1.42 | 63.02 | 67.13 | 71.24 | 75.35 | 79.46 | 83.57 |
0.32 | 29.60 | 1.08 | 82.71 | 88.11 | 93.50 | 98.89 | 104.29 | 109.68 |
0.22 | 29.70 | 0.75 | 120.31 | 128.15 | 136.00 | 143.85 | 151.69 | 159.54 |
0.12 | 29.80 | 0.41 | 220.56 | 234.95 | 249.33 | 263.72 | 278.10 | 292.49 |
- T(oC) = 5/9[T(oF) - 32]
- The calculation above is available as an excel file - vacuum.xls
- Altitude and pressure
• Gases and Compressed Air
Vacuum
Vacuum is defined as air pressure below atmospheric pressure.
Vacuum - Air Expansion Ratio
Convert vacuum air volume to standard air volume
Vacuum - Evacuation Time
Vacuum pumps - calculate flow rate and required evacuation time.
Vacuum Pipes - Flow Velocities
Air velocity diagrams for vacuum pipe lines.
Vacuum Pipes - Pressure Loss vs. Air Flow
Calculate pressure drops in vacuum pipe lines.
Vacuum Pumps - Exhaust Pipe Capacities
Capacities of vacuum pump exhaust pipes.
