Vacuum Pipes - Pressure Loss vs. Air Flow
Pressure drop in vacuum pipelines:
Air Flow - scfm - and Pressure Drop - in Hg/100 ft
The diagram is based on initial vacuum pressure 20 in Hg (67% vacuum) and steel pipes schedule 40.
  • 1 in Hg = 3.37 kPa
  • 1 scfm = 0.472 nl/s
Air Flow - nl/s - and Pressure Drop - kPa/100 m
Gases and Compressed Air
Air - SCFM versus ACFM and ICFM
Actual air compressor capacity (ACFM) vs. standard air capacity (SCFM) and inlet air capacity (ICFM).
Inches vs. Feet, Yards and Meters - Conversion Chart
Convert between inches, feet, yards and meters.
Vacuum
Vacuum is defined as air pressure below atmospheric pressure.
Vacuum - Air Expansion Ratio
Convert vacuum air volume to standard air volume
Vacuum - Evacuation Time
Vacuum pumps - calculate flow rate and required evacuation time.
Vacuum - Flow Measurement
Measure air volume flow in vacuum.
Vacuum - Pressure Units Converter
Converting between vacuum units like % vacuum - mm Mercury - psi - torr - micron - kPa.
Vacuum Pipes - Flow Velocities
Air velocity diagrams for vacuum pipe lines.
Vacuum Pumps - Exhaust Pipe Capacities
Capacities of vacuum pump exhaust pipes.
