Vacuum - Air Expansion Ratio
Standard air volume flow - SCFM - can be converted to actual air volume flow - ACFM - with the expanded air ratio equation
EAR = (30 / P) ((T + 460) / 520) (1)
EAR = ACFM / SCFM = expanded air ratio - ratio between actual air volume flow - ACFM - and standard air volume flow - SCFM
P = absolute vacuum pressure (inches Hg) where 29.92 inches Hg is normal atmospheric pressure and 0 inches Hg is absolute vacuum
T = temperature (oF)
Actual air volume flow can be calculated by multiplying standard air volume with the expanded air ratio.
Expanded air ratio for temperatures 60oF (15.5oC) are indicated in the diagram below:
The diagram above can be used to calculate air flow in SI-units where
- actual air flow - al/s
- standard air flow - sl/s
Example - Vacuum Expansion of Air
From the table above the expansion ratio of air from atmospheric pressure to 50% vacuum is 2.
The relation between vacuum in % and other pressure units are indicated in
• Gases and Compressed Air
Vacuum
Vacuum is defined as air pressure below atmospheric pressure.
Vacuum - Evacuation Time
Vacuum pumps - calculate flow rate and required evacuation time.
Vacuum - Flow Measurement
Measure air volume flow in vacuum.
Vacuum - Pressure Units Converter
Converting between vacuum units like % vacuum - mm Mercury - psi - torr - micron - kPa.
Vacuum Pipes - Flow Velocities
Air velocity diagrams for vacuum pipe lines.
Vacuum Pipes - Pressure Loss vs. Air Flow
Calculate pressure drops in vacuum pipe lines.
