Aluminum - Thermophysical Properties
T
(K)
ρ
(kg/m³)
c
(kJ/kg K)
k
(W/m K)
150 2726 0.683 250
200 2719 0.797 237
250 2710 0.859 235
300 2701 0.902 237
400 2681 0.949 240
600 2639 1.042 231
Material Properties
Aluminum - Melting Points of Binary Eutectic Alloys
Al - Aluminum - binary eutectic alloys and their melting points.
Aluminum Alloys - Mechanical Properties
Mechanical properties of aluminum alloys - tensile strength, yield strength and more.
Mechanical properties of some common aluminum alloys.
Aluminum Channels
Dimensions and static parameters of aluminum channels.
Aluminum Conductor Characteristics
Characteristics of all-aluminum conductors (AAC).
Metals - Specific Heats
Metals and Alloys - Densities
Metals, Metallic Elements and Alloys - Thermal Conductivities
Thermal conductivities of common metals, metallic elements aand alloys.
