Aluminum alloys are divided into the wrought and cast categories according to how they are produced. The wrought category includes rolling, extruding, drawing, forging, and a number of other more specialized processes. Cast alloys are poured molten into sand (sand casting) or high-strength steel (permanent mold or die casting) molds where they solidifies to produce the desired shape.
Density, specific heat and thermal conductivity related to temperature.
Mechanical properties of aluminum alloys - tensile strength, yield strength and more.
Dimensions and static parameters of aluminum channels.
Dimensions and static properties of aluminum I-beams - Imperial units.
