Copper - Density, Specific Heat and Thermal Conductivity vs. Temperature
Copper - Density, Specific Heat and Thermal Conductivity vs. Temperatures
T
(K)
ρ
(kg/m³)
c
(kJ/kg K)
k
(W/m K)
100 9009 0.254 480
150 8992 0.323 429
200 8973 0.357 413
250 8951 0.377 406
300 8930 0.386 401
400 8884 0.396 393
600 8787 0.431 379
800 8642 0.448 366
1000 8568 0.446 352
1200 8458 0.480 339
Material Properties
ASTM B88 - Seamless Copper Water Tubes - Dimensions
ASTM B88M - Seamless Copper Water Tubes - Metric Dimensions
Water and gas copper tubes according ASTM B88M - type K, L and M - metric units.
BS 2871 Copper Tubes Table X, Y and Z - Working Pressures vs. Size
Copper Alloys - Typical Applications
Typical use of copper alloys in architecture, automotive, electrical, building wire, energy, tube, pipe fittings, fuel gas, industrial and marine applications.
Copper Binary Eutectic Alloys - Melting Points
Cu - Copper - binary eutectic alloys and their melting points.
Copper Tubes - Pressure Loss vs. Water Flow
Water flow and pressure loss (psi/ft) due to friction in copper tubes ASTM B88 Types K, L and M.
Copper Tubes Type K - Dimensions and Physical Characteristics
Physical characteristics of copper tubes ASTM B 88 type K.
Copper Tubes Type K, L and M - Working Pressures vs. Size
Copper Wire - Electrical Resistance vs. Gauge
Gauge, weight, circular mils and electrical resistance in copper wire.
EN 1057 Copper Tubes for Water and Gas in Sanitary and Heating Applications - Dimensions
Dimensions of EN 1057 Copper and copper alloys - Seamless, round copper tubes for water and gas in sanitary and heating applications.
Metals and Alloys - Densities
