Copper Wire - Electrical Resistance vs. Gauge
Electrical resistance in copper wire:
For full table with Electrical Resistance and Weight - rotate the screen!
| AWG Gauge* | Area (Circular Mils) | Diameter ( mils, 1000th in) | Electrical Resistance (Ohms/1000 ft) | Weight (lb/1000 ft) | |
| at 77 oF (25 oC) | at 149 oF (65 oC) | ||||
| 0000 (4/0) | 212000 | 460 | 0.0500 | 0.057 | 641 |
| 000 (3/0) | 168000 | 410 | 0.0630 | 0.073 | 508 |
| 00 (2/0) | 133000 | 365 | 0.0795 | 0.092 | 403 |
| 0 (1/0) | 106000 | 325 | 0.100 | 0.116 | 319 |
| 1 | 83700 | 289 | 0.126 | 0.146 | 253 |
| 2 | 66400 | 258 | 0.159 | 0.184 | 201 |
| 3 | 52600 | 229 | 0.201 | 0.232 | 159 |
| 4 | 41700 | 204 | 0.253 | 0.292 | 126 |
| 5 | 33100 | 0.319 | 100 | ||
| 6 | 26300 | 162 | 0.403 | 0.465 | 79.5 |
| 7 | 20800 | 0.508 | 63.0 | ||
| 8 | 16500 | 128 | 0.641 | 0.739 | 50.0 |
| 9 | 13100 | 0.808 | 39.6 | ||
| 10 | 10400 | 102 | 1.02 | 1.18 | 31.4 |
| 11 | 8230 | 1.28 | 24.9 | ||
| 12 | 6530 | 81 | 1.62 | 1.87 | 19.8 |
| 13 | 5180 | 2.04 | 15.7 | ||
| 14 | 4110 | 64 | 2.58 | 2.97 | 12.4 |
| 15 | 3260 | 3.25 | 9.86 | ||
| 16 | 2580 | 51 | 4.09 | 4.73 | 7.82 |
| 17 | 2050 | 5.16 | 6.20 | ||
| 18 | 1620 | 40 | 6.51 | 7.51 | 4.92 |
| 19 | 1290 | 8.21 | 3.90 | ||
| 20 | 1020 | 32 | 10.4 | 11.9 | 3.09 |
| 21 | 810 | 13.1 | 2.45 | ||
| 22 | 642 | 25.3 | 16.5 | 19.0 | 1.94 |
| 23 | 509 | 20.8 | 1.54 | ||
| 24 | 404 | 20.1 | 26.2 | 30.2 | 1.22 |
| 25 | 320 | 33.0 | 0.970 | ||
| 26 | 254 | 15.9 | 41.6 | 48.0 | 0.769 |
| 27 | 202 | 52.5 | 0.610 | ||
| 28 | 160 | 12.6 | 66.2 | 76.4 | 0.484 |
| 29 | 127 | 83.4 | 0.384 | ||
| 30 | 101 | 10 | 105 | 121 | 0.304 |
| 31 | 79.7 | 133 | 0.241 | ||
| 32 | 63.2 | 8 | 167 | 193 | 0.191 |
| 33 | 50.1 | 211 | 0.152 | ||
| 34 | 39.8 | 6.3 | 266 | 307 | 0.120 |
| 35 | 31.6 | 335 | 0.095 | ||
| 36 | 25.0 | 5 | 423 | 488 | 0.076 |
| 37 | 19.8 | 533 | 0.060 | ||
| 38 | 15.7 | 4 | 673 | 776 | 0.048 |
| 39 | 12.5 | 848 | 0.038 | ||
| 40 | 9.9 | 3.1 | 1070 | 1230 | 0.020 |
*) solid strand
- 1 lb = 0.4536 kg
- 1 ft (foot) = 0.3048 m
• Electrical
Aluminum and Copper Wires - Electrical Resistance vs. Cross-Sectional Area
Electrical resistance in plain copper or aluminum wires.
Aluminum Conductor Characteristics
Characteristics of all-aluminum conductors (AAC).
AWG - Wire Gauge Sizes: Current Ratings, Charts, Measurements, and Conversion Guide
Amp ratings vs. US AWG wire gauge.
AWG Wire Gauge Chart & Table – American Wire Gauge (AWG) Standards
The AWG (American Wire Gauge) wire size chart with detailed specifications on wire diameter, resistance, and ampacity. Find conversions between AWG sizes and metric units for electrical and engineering applications.
Copper - Density, Specific Heat and Thermal Conductivity vs. Temperature
Density, specific heat and thermal conductivity of copper vs. temperature
Electric Circuits Voltage Drop
Ohm's law and voltage drop in electric circuits.
Electric Wire - Resistance
Electric resistance in wire made of Copper, Aluminum, Brass, Constantan, Nichrome, Platinum, Silver or Tungsten.
Electrical Conductivity - Elements and other Materials
Electric conductance is the ability of a element to conduct an electric current.
Electrical Formulas
Commonly used electrical formulas like Ohms Law and more.
Electrical Resistance vs. Conductance
The reciprocal of electrical resistance is conductance.
Electrical Units
Definition of common electrical units - like Ampere, Volt, Ohm, Siemens.
Nickel-Chromium Heater Wire - Temperature Rise vs. Amps
Electric resistance vs. temperature rise for Nickel-Chromium electrical heater wire.
Ohm's Law
The relation between voltage, current and electrical resistance.
Resistivity and Conductivity - Temperature Coefficients Common Materials
Resistivity, conductivity and temperature coefficients for common materials like silver, gold, platinum, iron and more..
SWG - Standard Wire Gauge
Imperial Standard Wire Gauge used with wire and sheet metal.
Weight vs. Gauges Chart
Gauge and weight chart for sheet steel, galvanized steel, stainless steel, aluminum and strip & tubing.
