CM - Circular Mil Area
The circular mil is a unit of area used especially when denoting the cross-sectional size of a wire or cable.
- A circular mil is the equivalent area of a circle whose diameter is 0.001 (10-3) inch, or approximately 0.7854 millionths of a square inch.
Mils of circular wire or cable can be calculated as:
mils = 1000 d (1)
d = diameter of cable or wire (inches)
Example - Calculating Mil
Mils of a 1 inch wire:
mils = 1000 (1 in)
= 1000
Mils of a 1/2 inch wire:
mils = 1000 (1/2 in)
= 500
The Circular Mil
The circular mil area of a wire or cable is equal to its diameter - expressed in mils squared:
CM = mil2 (2)
CM = circular mil area (CM)
The diameter in mil of a circular wire can be expressed as:
mil = CM1/2 (2b)
Example - Calculating mil area
The mil area of an 3/8 in wire (0.375 in or 375 mil) can be calculated as
CM= (375 mils) (375 mils)
= 140625 cmil
The mil of an circular wire with area 140625 CM can be calculated as
mil =1406251/2
= 375 mils
The Square Mil Area
The square mil is the area of a square whose sides are one mil, or 1×10-3 inch, and can be expressed as:
One Square Mil = (1×10-3)2
= 1×10-6 in2
Converting Circular Mil to Square Inch
- 1 Circular mil = 0.7854×10-6 Square Inch
Converting Circular Mil to Square Mil
- 1 Circular Mil = 0.7854 Square Mil
- 1 Square Mil = 1.27 Circular Mils
Converting Circular Mil to metric units
- 1 circular mil = 5.066×10-10 m2 = 5.066×10-6 cm2
- 1 m2 = 1.974×109 circular mil
- 1 cm2 = 1.974×105 circular mil
• Electrical
Area Units Converter
Convert between units of area.
AWG - American Wire Gauge vs. Circular Mils
AWG vs. diameter mil, circular mil, diameter in mm and area in mm2.
Standard Gauges
Standard gauges for wire and sheet - American, Birmingham, Washburn, Music, Stubs ..
SWG - Standard Wire Gauge
Imperial Standard Wire Gauge used with wire and sheet metal.
