Weight vs. Gauges Chart
Wire gauge is a measure for the size of a wire, either in diameter or in cross sectional area.
Gauge and weight chart for sheet steel, galvanized steel, stainless steel, aluminum and strip & tubing:
For full table with Stainless Steel, Aluminum, Strip and Tubing - rotate the screen!
| Gauge | US Standard Gauge | Sheet Steel | Galvanized Steel | Stainless Steel | Aluminum | Strip & Tubing | ||||
| (inches) | Gauge Decimal (inches) | Weight (lb/ft2) | Gauge Decimal (inches) | Weight (lb/ft2) | Gauge Decimal (inches) | Weight (lb/ft2) | Gauge Decimal (inches) | Weight (lb/ft2) | Gauge Decimal (inches) | |
| 44 | 0.0047 | |||||||||
| 43 | 0.0049 | |||||||||
| 42 | 0.0051 | |||||||||
| 41 | 0.0053 | |||||||||
| 40 | 0.0055 | |||||||||
| 39 | 0.0059 | |||||||||
| 38 | 0.0063 | 0.0060 | 0.0062 | 0.0040 | ||||||
| 37 | 0.0066 | 0.0064 | 0.0066 | 0.0045 | ||||||
| 36 | 0.0070 | 0.0067 | 0.0070 | 0.0050 | 0.004 | |||||
| 35 | 0.0078 | 0.0075 | 0.0078 | 0.0056 | 0.005 | |||||
| 34 | 0.0086 | 0.0082 | 0.0086 | 0.0063 | 0.007 | |||||
| 33 | 0.0094 | 0.0090 | 0.0094 | 0.0071 | 0.008 | |||||
| 32 | 0.0102 | 0.0097 | 0.0102 | 0.0080 | 0.009 | |||||
| 31 | 0.0109 | 0.0105 | 0.0109 | 0.0089 | 0.010 | |||||
| 30 | 0.0125 | 0.0120 | 0.500 | 0.016 | 0.656 | 0.0125 | 0.0100 | 0.141 | 0.012 | |
| 29 | 0.0141 | 0.0135 | 0.563 | 0.017 | 0.719 | 0.0141 | 0.0113 | 0.160 | 0.013 | |
| 28 | 0.0156 | 0.0149 | 0.625 | 0.019 | 0.781 | 0.0156 | 0.0126 | 0.178 | 0.014 | |
| 27 | 0.0172 | 0.0164 | 0.688 | 0.020 | 0.844 | 0.0172 | 0.0142 | 0.200 | 0.016 | |
| 26 | 0.0188 | 0.0179 | 0.750 | 0.022 | 0.906 | 0.0187 | 0.756 | 0.0159 | 0.224 | 0.018 |
| 25 | 0.0219 | 0.0209 | 0.875 | 0.025 | 1.031 | 0.0219 | 0.0179 | 0.253 | 0.020 | |
| 24 | 0.0250 | 0.0239 | 1.000 | 0.028 | 1.156 | 0.0250 | 1.008 | 0.0201 | 0.284 | 0.022 |
| 23 | 0.0281 | 0.0269 | 1.125 | 0.031 | 1.281 | 0.0281 | 0.0226 | 0.319 | 0.025 | |
| 22 | 0.0313 | 0.0299 | 1.250 | 0.034 | 1.406 | 0.0312 | 1.26 | 0.0253 | 0.357 | 0.028 |
| 21 | 0.0344 | 0.0329 | 1.375 | 0.037 | 1.531 | 0.0344 | 0.0285 | 0.402 | 0.032 | |
| 20 | 0.0375 | 0.0359 | 1.500 | 0.040 | 1.656 | 0.0375 | 1.512 | 0.0320 | 0.452 | 0.035 |
| 19 | 0.0438 | 0.0418 | 1.750 | 0.046 | 1.906 | 0.0437 | 0.0359 | 0.507 | 0.042 | |
| 18 | 0.0500 | 0.0478 | 2.000 | 0.052 | 2.156 | 0.0500 | 2.016 | 0.0403 | 0.569 | 0.049 |
| 17 | 0.0563 | 0.0538 | 2.250 | 0.058 | 2.406 | 0.0562 | 0.0453 | 0.639 | 0.058 | |
| 16 | 0.0625 | 0.0598 | 2.500 | 0.064 | 2.656 | 0.0625 | 2.52 | 0.0508 | 0.717 | 0.065 |
| 15 | 0.0703 | 0.0673 | 2.813 | 0.071 | 2.969 | 0.0703 | 0.0571 | 0.806 | 0.072 | |
| 14 | 0.0781 | 0.0747 | 3.125 | 0.079 | 3.281 | 0.0781 | 3.15 | 0.0641 | 0.905 | 0.083 |
| 13 | 0.0938 | 0.0897 | 3.750 | 0.093 | 3.906 | 0.0937 | 0.0720 | 1.016 | 0.095 | |
| 12 | 0.1094 | 0.1046 | 4.375 | 0.108 | 4.531 | 0.1094 | 4.41 | 0.0808 | 1.140 | 0.109 |
| 11 | 0.1250 | 0.1196 | 5.000 | 0.123 | 5.156 | 0.1250 | 5.04 | 0.0907 | 1.280 | 0.120 |
| 10 | 0.1406 | 0.1345 | 5.625 | 0.138 | 5.781 | 0.1406 | 5.67 | 0.1019 | 1.438 | 0.134 |
| 9 | 0.1563 | 0.1495 | 6.250 | 0.153 | 6.406 | 0.1562 | 0.1144 | 1.614 | 0.148 | |
| 8 | 0.1719 | 0.1644 | 6.875 | 0.168 | 7.031 | 0.1719 | 6.93 | 0.1285 | 1.813 | 0.165 |
| 7 | 0.1875 | 0.1793 | 7.500 | 0.1875 | 7.871 | 0.1443 | 2.036 | 0.180 | ||
| 6 | 0.2031 | 0.1943 | 8.125 | 0.2031 | 0.1620 | 2.286 | 0.203 | |||
| 5 | 0.2188 | 0.2092 | 8.750 | 0.2187 | 0.1819 | 0.220 | ||||
| 4 | 0.2344 | 0.2242 | 9.375 | 0.2344 | 0.2043 | 0.238 | ||||
| 3 | 0.2500 | 0.2391 | 10.00 | 0.2500 | 0.2294 | 0.259 | ||||
| 2 | 0.2656 | 0.2656 | 0.2576 | 0.284 | ||||||
| 1 | 0.2813 | 0.2812 | 0.2893 | 0.300 | ||||||
| 1/0 (0) |
0.3125 | 0.3125 | 0.3249 | 0.340 | ||||||
| 2/0 (00) |
0.3438 | 0.3437 | 0.3648 | 0.380 | ||||||
| 3/0 (000) |
0.3750 | 0.3750 | 0.4096 | 0.425 | ||||||
| 4/0 (0000) |
0.4063 | 0.4062 | 0.4600 | 0.454 | ||||||
| 5/0 (00000) |
0.4375 | 0.4375 | 0.5165 | 0.500 | ||||||
| 6/0 (000000) |
0.4688 | 0.4687 | 0.5800 | |||||||
| 7/0 (00000000) |
0.5000 | |||||||||
- 1 ft2 = 0.0929 m2
- 1 lb = 0.4536 kg
AWG - American Wire Gauge vs. Circular Mils
AWG vs. diameter mil, circular mil, diameter in mm and area in mm2.
AWG Wire Gauge Chart & Table – American Wire Gauge (AWG) Standards
The AWG (American Wire Gauge) wire size chart with detailed specifications on wire diameter, resistance, and ampacity. Find conversions between AWG sizes and metric units for electrical and engineering applications.
BWG - Birmingham Wire Gauge
Used to determine wall thickness of pipe - in gauge and decimal parts of inch.
Copper Wire - Electrical Resistance vs. Gauge
Gauge, weight, circular mils and electrical resistance in copper wire.
Mild Steel - Square Bars Weight
Typical weights of mild steel square bars.
Standard Gauges
Standard gauges for wire and sheet - American, Birmingham, Washburn, Music, Stubs ..
Steel Flats - Weights
Steel Plate Weight Guide: Calculator & Data Table
SWG - Standard Wire Gauge
Imperial Standard Wire Gauge used with wire and sheet metal.
Welded Steel Pipes - Weights
Nominal weights of welded steel pipes ranging 26 - 60 inches.
