BWG
The wall thickness of a pipe is normally given in decimal parts of an inch rather than as a fraction or gauge number. When gauge number is given for a pipe without reference to a system, Birmingham Wire Gauge - BWG - is implied.
Maximum current (amps) in a 12V electrical circuit vs. size (AWG) and length of wire.
Pipes and tubes are not exactly the same
Standard gauges for wire and sheet - American, Birmingham, Washburn, Music, Stubs ..
Imperial Standard Wire Gauge used with wire and sheet metal.
Gauge and weight chart for sheet steel, galvanized steel, stainless steel, aluminum and strip & tubing.
