Steel Tempering Colors
Steels containing more than 0.3% carbon are intended for heat treatment. Lower values of carbon makes the steel more tough than hard and suitable for applications where strength are important - like springs and high tensile bolts. Steels with carbon content in excess of 0.7% can be hardened to a higher degree and are suitable for applications where hardness rather than toughness is important. Tool steels make excellent cutting and drilling equipment as they contain tungsten, molybdenum, cobalt, and vanadium to increase heat resistance and durability.
Tempering steel is a two-step process where the
1. The tool is forged and hardened
  • tool end is heated to bright red color and forged
Carbon Steel Tempering Colors
TemperatureColor of Heated Carbon Steel
(oF)(oC)
2192 1200
2012 1100
1922 1050
1796 980
1706 930
1598 870
1490 810
1400 760
1292 700
1202 650
1112 600
  • tool quenched in cold water and cooled until touchable
  • tool is sharpened and polished
2. The tool is tempered
  • tool heated to tempering temperature as indicated below
(oF)(oC)
600 316   Scrapers, spokeshaves
560 293   Screwdrivers, springs, gears
540 282   Cold chisels, center punches
520 271   Taps <= 1/4 inch
500 260   Axes, wood chisels, drifts, taps >= 1/ inch, nut taps, thread dies, press tools
480 249   Twist drills, large taps, knurls
460 238   Dies, punches, bits, reamers
450 232   Twist drills for hard use
440 227   Turning tools, lathe tools, scrapers, milling, cutters, reamers
430 221   Edge tools, reamers
420 216   Knives, hammers
Note that oil baths and salt bats are also used extensively for tempering steel tools. Lead baths and sand baths are also used.
If steel is heated in an oxidizing atmosphere - like air - a film of oxide forms on the surface and the color changes as the temperature increases. The colors are affected to some extent by the composition of the steel and the method may not be dependable.
Melting Points of Heat-Treating Baths
MaterialMelting Point
(oF)(oC)
35% lead, 65% tin 358 181
50% sodium nitrate, 50% porassium nitrate 424 218
Tin 450 232
Sodium nitrate 586 308
Lead 620 327
Potassium nitrate 642 339
45% sodium chloride, 50% sodium sulfate 1154 623
Sodium chloride 1474 801
Sodium sulfate 1618 881
Barium chloride 1760 960
Material Properties
Miscellaneous
Brinell Hardness Number - BHN
The Brinell hardness test of metals and alloys.
Carbon and Low-Alloy Steel Classifications
Steel is considered to be carbon steel when no minimum content is specified or required for chromium, cobalt, columbium (niobium), molybdenum, nickel, titanium, tungsten, vanadium or zirconium.
Color Mixing Theory
Subtractive and additive color mixing.
Stainless Steel Classifications
Stainless steels are commonly grouped into martensitic stainless steels, ferritic stainless steels, austenitic stainless steels, duplex (ferritic-austenitic) stainless steels, and precipitation-hardening stainless steels.
Stainless Steels - Identification Tests
Magnetic, spark, hardness and acid identification tests for austenitic, martensitic and ferritic stainless steels.
Welding Temperatures
Melting and welding temperatures.
