Silver Binary Eutectic Alloys - Melting Points
The melting point of an alloy of two (binary) or more metals depends on the relative proportions of the ingredients.
- an eutectic mixture is the mixture where the melting point is as low as possible
Binary eutectic Silver - Ag - alloys, with composition and melting points are indicated below:
| Alloy Component | Weight of Alloy Component (%) | Melting Point | |
| K | oF | ||
| Al - Aluminum | 25 | 835 | 1044 |
| As - Arsenic | 18 | 813 | 1004 |
| Ca - Calcium | 18 | 820 | 1017 |
| Ce - Cerium | 84 | 798 | 977 |
| Cu - Copper | 28 | 1050 | 1431 |
| Ge - Germanium | 18 | 924 | 1204 |
| La - Lanthanum | 77 | 791 | 964 |
| Li - Lithium | 89 | 418 | 293 |
| Mg - Magnesium | 52 | 745 | 882 |
| Pb - Lead (Plumbum) | 97.5 | 577 | 579 |
| Pd - Palladium | 25.6 | 924 | 1204 |
| Sb - Antimony (Stibium) | 44 | 758 | 905 |
| Si - Silicon | 2.96 | 1110 | 1539 |
| Sr - Strontium | 73 | 709 | 817 |
| Te - Tellurium | 69 | 623 | 662 |
| Th - Thorium | 15 | 1167 | 1641 |
| Zr - Zirconium | 93 | 1100 | 1521 |
- T (oC) = 5/9 (T (oF) - 32)
• Melting and Freezing Points
Metals and Alloys - Densities
Molybdenum Binary Eutectic Alloys - Melting Points
Mo - Molybdenum - binary eutectic alloys and melting points.
Nickel Binary Eutectic Alloys - Melting Points
Ni - Nickel - binary eutectic alloys and melting points.
