The potential difference between an anode and a cathode can be measured by a voltage measuring device but since the absolute potential of an anode or cathode cannot be measured directly - all potential measurements are made against a standard electrode. The standard electrode potential is set to zero and the measured potential difference can be considered as absolute.
Standard Hydrogen Electrode
- The half-cell in which the hydrogen reaction takes place is called the Standard Hydrogen Electrode - SHE
Standard Electrode Potential
- The potential difference measured between a metal M and the Standard Hydrogen Electrode - SHE
The electro-chemical series (electro-motive series) is a list of metals arranged in order of their standard potentials to the hydrogen electrode:
| Element | Electrode Potential (volts) |
| Lithium | -3.04 |
| Rubidium | -2.92 |
| Potassium | -2.92 |
| Calcium | -2.87 |
| Barium | -2.80 |
| Sodium | -2.71 |
| Magnesium | -2.37 |
| Beryllium | -1.85 |
| Aluminum | -1.67 |
| Manganese | -1.19 |
| Zinc | -0.76 |
| Chromium | -0.74 |
| Tungsten | -0.58 |
| Iron | -0.44 |
| Cadmium | -0.40 |
| Cobalt | -0.28 |
| Nickel | -0.24 |
| Tin | -0.14 |
| Lead | -0.13 |
| Hydrogen | +0.00 |
| Antimony | +0.10 |
| Copper | +0.34 |
| Iodine | +0.54 |
| Silver | +0.80 |
| Mercury | +0.85 |
| Bromine | +1.07 |
| Platinum | +1.20 |
| Chlorine | +1.36 |
| Gold | +1.50 |
| Fluorine | +2.87 |
Note! - metals higher up in the electro-chemical series displaces metals lower in the series - which means that when connecting two metals with different potentials the metal with the lowest potential corrodes.
Corrosion Problem when Connecting Copper and Iron/Steel
A very common connection in piping systems are copper and iron/steel. with this connection iron/steel corrodes many times faster than iron/steel alone.
• Corrosion
• Electrical
Copper Tubes - Corrosion Resistance to Chemicals
Copper tubes corrosion resistance to different products and chemicals.
Elements - Boiling Points
Elements and their boiling points.
Metals - Specific Heats
Metals in Seawater - Galvanic Series
Galvanic series of metals in seawater.
Pipes - Corrosion Protection
A corrosion protection tutorial for piping systems.
Piping Materials - Galvanic Corrosion
Connecting pipes of different materials may cause galvanic corrosion and serious damage.
Potassium - Thermophysical Properties vs. Temperature
Thermophysical properties of potassium.
Silver Binary Eutectic Alloys - Melting Points
Ag - Silver - binary eutectic alloys and melting points.
Stainless Steels - Corrosion Resistance
Corrosion resistanse of AISI stainless steels in various environments.
Steel Pipes - Corrosion due to Oxygen
The influence of oxygen concentration and temperature on the corrosion of steel pipes.
Types of Corrosion
Uniform, pitting, galvanic, crevice, concentration cell and graphitic types of corrosion.
