(K)
Specific heat of metal alloys like brass, bronze and more.
Content of metals in minerals.
Boiling points and specific heat of liquid metals.
Metals and their latent heat of fusion.
Resistivity, conductivity and temperature coefficients for common materials like silver, gold, platinum, iron and more..
Speed of sound in solids and metals like aluminum, brass, concrete and more.
