Mineral Wool Insulation
Mineral wool is made from molten glass, stone or slag that is spun into a fiber-like structure. Inorganic rock or slag are the main components (typically 98%) of stone wool. The remaining 2% organic content is generally a thermosetting resin binder (an adhesive) and a little oil.
Mineral wool thermal conductivity vs. temperature are indicated in the charts below:
- T (oC) = 5/9 (T (oF) - 32)
• Insulation
Calcium Silicate Insulation
Thermal conductivity of calcium silicate insulation - temperature and k-values.
Fiberglass Insulation
Thermal conductivity of fiberglass insulation - temperature and k-values.
Insulation Materials - Operating Temperature Limits
Temperature limits for commonly used insulation materials.
Minerals - Densities
Densities of minerals.
Perlite Insulation
Pipes - Insulated Heat Loss Diagrams
Heat loss (W/m) from 1/2 to 6 inches insulated pipesĀ - ranging insulation thickness 10 to 80 mm and temperature differences 20 to 180 degC.
Heat loss (W/ft) diagrams for 1/2 to 6 inches insulated pipesĀ - ranging insulation thickness 0.5 to 4 inches and temperature differences 50 to 350 degF.
Piping - Recommended Insulation Thickness
Recommended insulation thickness for heating systems like hot water and low, medium or high pressure steam systems.
Polyurethane Insulation
Thermal Conductivity of Common Materials - Solids, Liquids and Gases
Thermal conductivity of various common materials, including metals, gases, and building materials. Essential data for engineers, architects, and designers working with heat transfer and insulation.
Thermal Conductivity Units Converter
