Pipes - Insulated Heat Loss Diagrams
The heat loss diagrams below is based on metal pipes with fiber glass insulation, thermal conductivity 0.25 Btu/h oF ft2/in and outdoor condition with moderate wind 20 mph. A safety factor of 10% is included.
- indoor location - reduce values with 10%
- mineral wool insulation - increase values with 6%
- rigid cellular polyurethane - reduce values by 30%
- Heat loss diagram (W/ft)
Pipe Heat Loss - Insulation thickness 4 inches
- 1 W/ft = 3.41 Btu/h ft = 3.28 W/m
- 1 oF = 0.555 oC
Pipe Heat Loss - Insulation thickness 3 inches
Pipe Heat Loss - Insulation thickness 2.5 inches
Pipe Heat Loss - Insulation thickness 2 inches
Pipe Heat Loss - Insulation thickness 1.5 inches
Pipe Heat Loss - Insulation thickness 1 inch
Pipe Heat Loss - Insulation thickness 0.5 inches
• Heat Loss and Insulation
• Insulation
• Insulation and Heat Loss from Steam and Condesate Pipe Lines
Heat loss from uninsulated and insulated steam and condensate pipes and tanks. Calculate insulation thicknesses.
Calcium Silicate Insulation
Thermal conductivity of calcium silicate insulation - temperature and k-values.
Copper Tubes - Heat Losses
Heat loss from uninsulated copper tubes vs. temperature differences between tube and air.
Copper Tubes - Uninsulated Heat Losses
Heat loss from uninsulated copper pipes - dimensions ranging 1/2 - 4 inches.
Heat Loss from Oil Filled Tanks and Pipe Lines
Heat loss from insulated and non insulated sheltered and exposed oil tanks and pipes.
Heat Traced Pipes - Wrapping Factor
Wrapping factor when the heat loss from a pipe or tube is higher than the capacity of the heat trace cable.
Insulated Copper Tubes - Heat Loss
Heat loss to surrounding air from insulated copper tubes.
Mineral Wool Insulation
Oil Filled Tanks - Heat Loss
Heat loss from insulated and uninsulated, sheltered and exposed heated oil tanks.
Heat loss (W/m) from 1/2 to 6 inches insulated pipes - ranging insulation thickness 10 to 80 mm and temperature differences 20 to 180 degC.
Pipes and Cylinders - Conductive Heat Loss
Conductive heat losses through cylinder or pipe walls.
Polyurethane Insulation
Steam Pipes - Heat Losses
The amount of condensate generated in a steam pipe depends on the heat loss from the pipe to the surroundings.
Steam Pipes - Heat Losses (W/m)
Heat losses from un-insulated steam pipes.
Steam Tracing Pipe Lines
Steam tracing of pipe lines can be done to maintain appropriate product temperatures.
Steel Pipes - Heat Loss Diagram
Heat loss from steel pipes and tubes - dimensions 1/2 to 12 inches.
