Oil Filled Tanks - Heat Loss
Heat transfer rates - α - for heated oil filled tanks.
Sheltered Tank
Tank Temperature | Heat Transfer Rate - α - | ||||
Uninsulated | Insulated | ||||
(oC) | (oF) | (W/(m2 oC)) | (Btu/(hr ft2 oF)) | (W/(m2 oC)) | (Btu/(hr ft2 oF)) |
10 | 50 | 6.8 | 1.2 | 1.7 | 0.3 |
27 | 80 | 7.4 | 1.3 | 1.8 | 0.33 |
38 | 100 | 8.0 | 1.4 | 2.0 | 0.35 |
Exposed Tank
10 | 50 | 8.0 | 1.4 | 2.0 | 0.35 |
27 | 80 | 8.5 | 1.5 | 2.1 | 0.38 |
38 | 100 | 9.0 | 1.6 | 2.3 | 0.4 |
Heat loss transfer rate depends heavily on
- the ambient conditions - whether it is wind, sun or raining or snowing on the external surface
- the internal conditions in the tank - the viscosity of the oil and the internal circulation in the tank
The total heat loss from an application can in general (in SI-units) be expressed as:
Q = α A dt (1)
Q = heat loss (W)
α = heat transfer rate (W/(m2oC))
A = area (m2)
dt = temperature difference (oC)
Example - Heat Loss from an Exposed Insulated Oil Tank
The total heat loss from an insulated tank with 1000 m2 exposed surface, filled with heated oil at 38 oC, surrounding temperature of 0 oC and a heat transfer rate of 2.27 W/m2 oC - can be calculated as:
Q = (2.27 W/(m2oC)) (1000 m2) ((38 oC) - (0 oC))
= 86260 W
= 86.3 kW
• Heating Systems
• Insulation and Heat Loss from Steam and Condesate Pipe Lines
Heat loss from uninsulated and insulated steam and condensate pipes and tanks. Calculate insulation thicknesses.
• Steam and Condensate
Content in Horizontal - or Sloped - Cylindrical Tanks or Pipes
Volume of partly filled horizontal or sloped cylindrical tanks or pipes - online calculator.
Fuel Oil Storage Tanks
Fuel oil storage tanks dimensions.
Heat Loss from Oil Filled Tanks and Pipe Lines
Heat loss from insulated and non insulated sheltered and exposed oil tanks and pipes.
Heat Loss from Open Water Tanks
Due to evaporation the heat loss from an open water tank like a swimming pool may be considerable.
Oil Tanks - Heat Loss
Heat loss from lagged and unlagged, sheltered and exposed oil tanks.
Pipes - Bare Surface Heat Loss
Heat loss vs. surface temperature.
Pipes - Insulated Heat Loss Diagrams
Heat loss (W/m) from 1/2 to 6 inches insulated pipesĀ - ranging insulation thickness 10 to 80 mm and temperature differences 20 to 180 degC.
Heat loss (W/ft) diagrams for 1/2 to 6 inches insulated pipesĀ - ranging insulation thickness 0.5 to 4 inches and temperature differences 50 to 350 degF.
Pipes and Cylinders - Conductive Heat Loss
Conductive heat losses through cylinder or pipe walls.
Pipes Submerged in Oil or Fat - Heat Emission
Heat emission from steam or water heating pipes submerged in oil or fat - forced and natural circulation.
Rectangular Tanks - Volumes
Tank volume per foot depth.
Submerged Coils - Heat Transfer Coefficients
Heat transfer coefficients for steam and hot water coils submerged in oil tanks.
