Oil Tanks - Heat Loss
Heat loss from sheltered and exposed, lagged and unlagged oil tanks are indicated in the table below:
Condition
Heat loss
W/m2K
(Btu/hr ft2 oF)
Oil temperature
up to 10 oC
(up to 50 oF)
10 - 27 oC
(50 - 80 oF)
27 - 38 oC
(80 - 100 oF)
Unlagged Sheltered 6.8
(1.2)
7.4
(1.3)
8.0
(1.4)
Exposed 9.0
(1.4)
8.5
(1.5)
9.0
(1.6)
Lagged Sheltered 1.7
(0.3)
1.8
(0.33)
2.0
(0.35)
Exposed 2.0
(0.35)
2.1
(0.38)
2.25
(0.4)
Heat Loss and Insulation
Fuel Oil Storage Tanks
Fuel oil storage tanks dimensions.
Heat Loss from Open Water Tanks
Due to evaporation the heat loss from an open water tank like a swimming pool may be considerable.
Oil Filled Tanks - Heat Loss
Heat loss from insulated and uninsulated, sheltered and exposed heated oil tanks.
Oil Pipes - Heat Loss
Heat loss in W/mK and Btu/hr ft degF from oil tubes ranging temperatures 10 - 38 degC (50 - 100 degF).
Pipes Submerged in Oil or Fat - Heat Emission
Heat emission from steam or water heating pipes submerged in oil or fat - forced and natural circulation.
Rectangular Tanks - Volumes
Tank volume per foot depth.
Specific Heat of Common Liquids and Fluids
Submerged Coils - Heat Transfer Coefficients
Heat transfer coefficients for steam and hot water coils submerged in oil tanks.
