Double-jacketed tanks under European Standards EN-12285-1 and EN-12285-2
Capacity (litre) | Diameter (mm) | Length (mm) | Weight (kg) |
1500 | 1250 | 1580 | 580 |
2000 | 1250 | 2000 | 700 |
3000 | 1250 | 2720 | 880 |
4000 | 1250 | 3560 | 1100 |
5000 | 1500 | 3150 | 1200 |
6000 | 1500 | 3710 | 1370 |
8000 | 1900 | 3260 | 1760 |
10000 | 1900 | 3960 | 2060 |
12000 | 1900 | 4670 | 2380 |
15000 | 1900 | 5910 | 2940 |
20000 | 1900 | 7860 | 3820 |
2500 | 4680 | 3610 | |
25000 | 1900 | 9810 | 4720 |
2500 | 5680 | 4230 | |
30000 | 1900 | 11510 | 5571 |
2500 | 6680 | 4950 | |
40000 | 2500 | 8830 | 6390 |
3000 | 6280 | 6200 | |
50000 | 2500 | 10820 | 7600 |
3000 | 7820 | 7470 | |
60000 | 2500 | 12970 | 9100 |
3000 | 9170 | 8680 | |
80000 | 3000 | 12220 | 11160 |
100000 | 3000 | 15080 | 13590 |
120000 | 3000 | 17700 | 15930 |
Volume of partly filled horizontal or sloped cylindrical tanks or pipes - online calculator.
Volume in US gallons and liters.
Convert rectangular and oval duct geometry to a equivalent circular diameter - online calculator with imperial and SI-units.
Heat loss from insulated and uninsulated, sheltered and exposed heated oil tanks.
Heat loss from lagged and unlagged, sheltered and exposed oil tanks.
Tank volume per foot depth.
