Steam - Flow vs. kW Rating
Steam flow rate when kW rating is known can be calculated as
ms = 3600 P / he                                     (1)
ms = steam flow rate (kg/h)
P = load in kW (kW)
he = specific enthalpy of evaporation of steam at working pressure (kJ/kg)
Thermodynamics
Thermodynamics of steam and condensate systems.
Boiler Capacities
Steam boilers output can be expressed in Boiler Horsepower, MBTU or in Pounds of Steam delivered per hour.
Heating Systems - Steam and Condensate Loads
Sizing Steam Pipes (kg/h)
Steam is a compressible gas where pipe line mass flow capacity depends on steam pressure.
Sizing Steam Pipes (lb/h)
Steam Consumption for some Typical Steam Heated Consumers
Steam consumption rates for typical steam heated consumers in industries like bakeries, breweries, paper factories etc.
Units of Heat - BTU, Calorie and Joule
The most common units of heat BTU - British Thermal Unit, Calorie and Joule.
