Glycerine - Boiling and Freezing Points
The boiling points of glycerine (also called glycerin or glycerol) water mixtures are reduced with increased amounts of glycerine. The freezing points are reduced until glycerine concentration is 66.7 % (mass). Increasing the glycerine concentration above 66.7 % will increase the freezing point as indicated below.
Glycerine to Water Concentration
(% by mass, weight)
Specific Gravity
(at 60oF, 15.6oC)
Freezing PointBoiling Point
(oF)(oC)(oF)(oC)
98.2 1.261 56 13.3 554 290
95 1.253 46 7.8 332 167
90 1.240 29 -1.7 281 138
80 1.213 -5 -20.6 250 121
70 1.185 -38 -38.9 237 114
66.7 1.178 -51 -46.1 234 112
60 1.157 -30 -34.4 228 109
50 1.129 -9 -22.8 223 106
40 1.102 4 -15.6 219 104
30 1.075 15 -9.4 217 103
20 23 -5.0
10 28.9 -1.7
Boiling Points of Fluids
Material Properties
Melting and Freezing Points
Heat Transfer Coefficients in Heat Exchanger Surface Combinations
Hydrocarbons - Physical Data
Isopropanol (2-Propanol) based Freeze Protected Water Solutions
Freezing and flash points of isopropanol (2-Propanol) based water solutions or brines.
Methanol Freeze Protected Heat Transfer Liquids
Freezing and flash points for methanol or methyl based heat-transfer fluids or brines.
