For many heat-transfer applications it is necessary to use a heat-transfer fluid with lower freezing point than water. The most common antifreeze fluid - ethylene glycol - must not be used where there is a chance of leakage to potable water or food processing systems.
In food processing systems the common heat-transfer fluid is based on propylene glycol.
Freezing Points of Propylene Glycol based Water Solutions
Freezing point of propylene glycol based water solutions at different temperatures:
| Propylene Glycol Solution (%) |
by mass | 0 | 10 | 20 | 30 | 40 | 50 | 60 |
| by volume | 0 | 10 | 19 | 29 | 40 | 50 | 60 | |
| Freezing Points | oF | 32 | 26 | 18 | 7 | -8 | -29 | -55 |
| oC | 0 | -3 | -8 | -14 | -22 | -34 | -48 |
Due to slush creation - a propylene glycol and water solution should not be used close to freezing points.
Specific Gravities of Propylene Glycol Solutions
Specific gravity of propylene glycol solutions:
| by volume | 0 | 10 | 20 | 29 | 40 | 50 | 60 | |
| Specific Gravity - SG - 1) | 1.000 | 1.008 | 1.017 | 1.026 | 1.034 | 1.041 | 1.046 | |
1) Specific gravity based on propylene glycol solutions with temperature 60 oF.
Densities of Propylene Glycol water Solutions
| Mass Fraction of Propylene Glycol in Solution | Density - ρ - (kg/m3) | |||||||||||
| Temperature - t - (oC) | ||||||||||||
| -45 | -33 | -22 | -13 | -7 | -3 | 0 | 20 | 40 | 60 | 80 | 100 | |
| 0 | 1000 | 998 | 993 | 983 | 972 | 958 | ||||||
| 0.1 | 1012 | 1012 | 1006 | 998 | 988 | 976 | 965 | |||||
| 0.2 | 1023 | 1022 | 1022 | 1014 | 1004 | 992 | 980 | 967 | ||||
| 0.3 | 1035 | 1034 | 1032 | 1031 | 1022 | 1010 | 997 | 983 | 969 | |||
| 0.4 | 1049 | 1047 | 1044 | 1043 | 1041 | 1030 | 1016 | 1002 | 987 | 971 | ||
| 0.5 | 1064 | 1061 | 1058 | 1055 | 1053 | 1051 | 1038 | 1023 | 1006 | 990 | 974 | |
| 0.6 | 1080 | 1078 | 1074 | 1069 | 1065 | 1063 | 1061 | 1046 | 1029 | 1011 | 994 | 976 |
Boiling Points of Propylene Glycol Solutions
Boiling points of propylene glycol solutions:
| Boiling Points (oF) | 212 | 212 | 213 | 216 | 219 | 222 | 225 | |
- T (oC) = 5/9 (T (oF) - 32)
Specific Heats of Propylene Glycol Solutions
Specific heat of propylene glycol solutions:
| Specific Heat - cp - (Btu/lb oF) |
1.000 | 0.980 | 0.960 | 0.935 | 0.895 | 0.850 | 0.805 | |
- 1 Btu/(lbmoF) = 4186.8 J/(kg K) = 1 kcal/(kgoC)
• Boiling Points of Fluids
• Piping Systems
Antifreeze - Ethylene Glycol Volume vs. Temperature Rating
Freeze protecting of cooling systems - temperature rating vs. required amount of antifreeze.
Antifreeze - Ethylene Glycol vs. Propylene Glycol
Comparing ethylene glycol and propylene glycol antifreeze properties.
Calcium Chloride Water Solutions
Freezing point, density, specific heat and dynamic viscosity of Calcium Chloride Water coolants.
Dowtherm A
Physical properties of Dowtherm A.
Ethanol Freeze Protected Water Solutions
Freezing temperature and flash points for ethanol based water solutions or brines.
Ethanol Water Mixtures - Densities vs. Temperature
Density of Ethyl Alcohol aqueous solutions.
Freeze Protection of Water based Heat Transfer Fluids
Comparing antifreezes used in water based heat transfer fluids or brines.
Freezing Mixtures and Cooling Agents
Freezing mixtures, cooling agents and freezing points.
Glycerine - Boiling and Freezing Points
Boiling and freezing points of glycerine aqueous solutions.
Hot Water Heating System Online Design Application
Isopropanol (2-Propanol) based Freeze Protected Water Solutions
Freezing and flash points of isopropanol (2-Propanol) based water solutions or brines.
Liquids - Freezing and Melting Points
Common fluids and their freezing and melting points.
Methanol Freeze Protected Heat Transfer Liquids
Freezing and flash points for methanol or methyl based heat-transfer fluids or brines.
Mixing Fluids
Final mass and temperature when mixing fluids.
Secondary Coolants - Properties
Comparing properties like specific gravity, freezing points and viscosity for secondary coolants like calcium chloride, sodium chloride, ethylene glycol and propylene glycol.
Sodium Chloride Water Solutions
Freezing point, density, specific heat and dynamic viscosity of Sodium Chloride and Water coolant.
