Dowtherm A
DOWTHERM™ A from The Dow Chemical Company is a heat transfer fluid suitable for non-pressurized liquid phase systems with a maximum temperature of 550 °F (288 °C).
DOWTHERM™ A is a eutectic mixture of two very stable compounds
  • biphenyl - C12H10
  • diphenyl oxide - C12H10O
with practically the same vapor pressures - suitable as a indirect heat transfer fluid for
  • liquid phase systems - 15 oC to 400 oC (60 oF to 750 oF)
  • vapor phase systems - 257 oC to 400 oC (495 oF to 750 oF)
Physical properties
  • freeze point - 12 oC (56.6 oF)
  • boiling point (atmospheric) - 257 oC (494.8 oF)
  • flash point (SETA) - 113 oC (236 oF)
  • Fire point (C.O.C) - 118 oC (245 oF)
  • autoignition temperature - 599 oC (1110 oF)
  • density (25 oC, 75 oF) - 1056 kg/m3 (66 lb/ft3)
Dowtherm A - Saturated Liquid Properties Chart
Vapor Pressure, Viscosity, Specific Heat, Thermal Conductivity and Density are indicated in the chart below:
Heating Systems
Thermodynamics
Heat Transfer Coefficients in Heat Exchanger Surface Combinations
Hydrocarbons - Autoignition Temperatures and Flash Points
Autoignition temperatures and flash points (°C and °F) of different types of hydrocarbons with varying carbon numbers up to C12.
Methanol Freeze Protected Heat Transfer Liquids
Freezing and flash points for methanol or methyl based heat-transfer fluids or brines.
