Sodium Chloride Water Solutions
Freezing point, density, specific heat and dynamic viscosity of Sodium Chloride and Water coolant:
Freezing Point
Density
Specific Heat
Dynamic Viscosity
Calcium Chloride Water Solutions
Freezing point, density, specific heat and dynamic viscosity of Calcium Chloride Water coolants.
Ethanol Freeze Protected Water Solutions
Freezing temperature and flash points for ethanol based water solutions or brines.
Ethylene Glycol Heat-Transfer Fluid Properties
Freeze Protection of Water based Heat Transfer Fluids
Comparing antifreezes used in water based heat transfer fluids or brines.
Secondary Coolants - Properties
Comparing properties like specific gravity, freezing points and viscosity for secondary coolants like calcium chloride, sodium chloride, ethylene glycol and propylene glycol.
