Freezing Mixtures and Cooling Agents
Freezing points for water with freezing mixtures based on salt and ice:
Freezing Mixtures - Temperature Ranges
Freezing MixtureTemperature Change (oF)Temperature Change (oC)
FromToFromTo
  • Ammonium Nitrate (NH4NO3) - 1 part
  • Water - 1 part
50 3 10 -16
  • Calcium Chloride (CaCl2) - 3 parts
  • Snow or ice - 2 parts
32 -27 0 -33
  • Potassium Hydrate (KOH) - 4 parts
  • Snow or ice - 3 parts
32 -35 0 -37
  • Sal Ammoniac (NH4Cl) - 5 parts
  • Saltpeter (KNO3) - 5 parts
  • Water - 16 parts
50 10 10 -12
  • Sal Ammoniac (NH4Cl) - 1 part
  • Saltpeter (KNO3) - 1 part
  • Water - 1 part
46 -11 8 -24
  • Salt (NaCl) - 1 part
32 0 0 -18
  • Snow or ice - 1part
32 -0.4 0 -18
Ammonium Nitrate - Chrushed Ice or Snow in Water
  • 1 part Ammonium Nitrate - 0.94 parts Ice/water : temperature -4 oC
  • 1 part Ammonium Nitrate - 1.20 parts Ice/water : temperature -14 oC
  • 1 part Ammonium Nitrate - 1.31 parts Ice/water : temperature -17.5 oC
  • 1 part Ammonium Nitrate - 3.61 parts Ice/water : temperature -8 oC
Calcium Chloride - Chrushed Ice or Snow in Water
  • 1 part Calcium Chloride - 0.49 parts Ice/water : temperature -20 oC
  • 1 part Calcium Chloride - 0.61 parts Ice/water : temperature -39 oC
  • 1 part Calcium Chloride - 0.70 parts Ice/water : temperature -55 oC
  • 1 part Calcium Chloride - 1.23 parts Ice/water : temperature -22 oC
  • 1 part Calcium Chloride - 4.92 parts Ice/water : temperature -4 oC
Sodium Chloride - Chrushed Ice or Snow in Water
  • 1 part Sodium Chloride - 2 parts Ice/water : temperature -18 oC
Evaporating Liquid Gases at Atmospheric Pressure
  • Liquid Oxygen : temperature -183 oC
  • Liquid Nitrogen : temperature -196 oC
  • Liquid Helium : temperature -269 oC
Thermodynamics
Ethanol Freeze Protected Water Solutions
Freezing temperature and flash points for ethanol based water solutions or brines.
Ethanol Water Mixtures - Densities vs. Temperature
Density of Ethyl Alcohol aqueous solutions.
Ice - Thermal Properties
Thermal and thermodynamic properties of ice like density, thermal conductivity and specific heat at temperatures from 0 to -100 oC.
Isopropanol (2-Propanol) based Freeze Protected Water Solutions
Freezing and flash points of isopropanol (2-Propanol) based water solutions or brines.
Propane Butane Mixture - Evaporation Pressure
Saturated Ice and Steam - Thermodynamic Properties
Thermodynamic properties of saturated ice and steam - specific volume, enthalpy and entropy.
