Note! - the critical point is not the same as the triple point.
Cryogenic properties as density, boiling points and heat of evaporation for fluids like hydrogen, methane, oxygen, nitrogen, fluorine and helium.
Chemical, Physical and Thermal Properties of Helium - He.
Triple points for common substances.
