Usually Soluble | Exceptions | |
Acetates | CH 3 COO - | Moderately soluble: CH 3 COOAg |
Ammonium | NH 4 + | |
Chlorates | ClO 3 - | |
Perchlorates | ClO 4 - | |
Group 1 cations | Li + | |
Na + | ||
K + | ||
Rb + | ||
Cs + | ||
Halides | F - | Insoluble: MgF 2 , CaF 2 , SrF 2 , BaF 2 , PbF 2 |
Cl - | Insoluble: AgCl, Hg 2 Cl 2 , PbCl 2 , | |
Br - | Insoluble: AgBr, Hg 2 Br 2 , PbBr 2 , | |
I - | Insoluble: AgI, Hg 2 I 2 , PbI 2 , | |
Nitrates | NO 3 - | |
Nitrites | NO 2 - | Moderately soluble: AgNO 2 |
Sulfates | SO 4 2- | Moderate soluble: CaSO 4 , SrSO 4 , Ag 2 SO 4 Insoluble: BaSO 4 , PbSO 4 , HgSO 4 |
Usually Insoluble | Exceptions | |
Carbonates | CO 3 2- | Soluble: (NH 4 ) 2 CO 3 , Na 2 CO 3 , K 2 CO 3 |
Hydroxides | OH - | Soluble: LiOH, NaOH, KOH, Ba(OH) 2 Moderately soluble: Ca(OH) 2 , Sr(OH) 2 |
Phosphates | PO 4 3- | Soluble: (NH 4 ) 3 PO 4 , Na 3 PO 4 , K 3 PO 4 |
Sulfides | S 2- | Soluble: (NH 4 ) 2 S, Na 2 S, K 2 S, MgS, CaS |
Mixtures vs. solutions vs. suspensions.
Rules for naming inorganic ionic and covalent types of chemical compounds.
Salinity - salt content - of fresh, brackish and sea water.
The amount of a solute that can be dissolved in a solvent.
The equilibrium constant, Ksp, for aqueous solutions of ionic compounds at 25°C.
Definitions and examples of how to calculate wt%, molarity and how to prepare dilutions.
Solubility of sugar in water.
