Cooling Water - Pipe Lines
Main Pipes - maximum allowable flow, velocity and pressure drop
Cooling Water - Main Pipes
Pipe Size
(in)
FlowVelocityPressure Drop
(US gpm)(liter/s)(ft/s)(m/s)(ftH2O/100 feet)(Pa/100 m)
4 140 9 3.5 1.1 2.2 21827
6 380 24 4.2 1.3 1.9 18877
8 650 41 4.2 1.3 1.4 13371
10 1100 69 4.2 1.3 1.2 11700
12 1800 114 4.5 1.4 1.2 12093
14 2200 139 5.1 1.6 1.1 11208
16 3300 208 5.9 1.8 1.2 11405
18 4500 284 6.2 1.9 1.2 11503
20 6000 379 6.7 2.0 1.2 11503
24 11000 694 7.8 2.4 1.2 11700
30 19000 1199 8.7 2.6 1.1 10913
3 70 4 3.0 0.9 2.3 22712
Lateral Pipes - maximum allowable flow, velocity and pressure drop
Cooling Water - Lateral Pipes
Pipe Size
(in)
4 200 13 5.1 1.5 4.3 42179
6 500 32 5.6 1.7 3.2 31364
8 900 57 5.8 1.8 2.5 24383
10 1500 95 6.1 1.9 2.1 20745
12 2400 151 6.8 2.1 2.1 20647
14 3100 196 7.2 2.2 2.1 20647
16 4500 284 7.9 2.4 2.1 20549
18 6000 379 8.3 2.5 2.0 19565
3 100 6 4.3 1.3 4.5 43949
Piping Systems
Calculating Cooling Loads
Calculating chiller and cooling tower refrigeration loads - in tons.
Chilled Water Systems
Chilled water system equations - evaporator and condenser flow rates.
Cooling Tower Efficiency
Maximum cooling tower efficiency is limited by the cooling air wet-bulb temperature.
Insulation of Cooling Systems
Cooling systems and insulation thickness.
Water - Absolute (Dynamic) Viscosity vs. Temperature and Pressure
Absolute viscosity for water in centipoises for temperatures between 32 - 200oF.
Water Systems - Maximum Flow Velocities
Water velocities in pipes and tubes should not exceed certain limits.
