ν = μ / ρ = kinematic viscosity (m 2 /s, ft 2 /s)
Equation (1) is only valid at laminar conditions where Reynolds Number is less than 2300 . For turbulent conditions where Reynolds Number exceeds 4000 the Colebrook equation should be used to calculate the friction coefficient.
In practice laminar flow is only actual for viscous fluids - like crude oil, fuel oil and other oils.
The friction coefficient for laminar flow indicated in the Moody diagram (SI based):
