Note! The hydraulic diameter is not the same as the equivalent diameter. The equivalent diameter is the diameter of a circular duct or pipe that gives the same pressure loss as a rectangular duct or pipe.
Head loss or major loss in air ducts - equations and online calculator for rectangular and circular ducts - Imperial and SI units.
Calculate velocities in circular and rectangular ducts - imperial and SI-units - online calculator.
Circular ducts sross-sectional areas.
Minor pressure and head loss in pipes vs. equivalent length in tubes and duct systems.
Geometric relationships like area, wetted perimeter and hydraulic diameter.
Convert rectangular and oval duct geometry to a equivalent circular diameter - online calculator with imperial and SI-units.
The Hazen-Williams equation can be used to calculate the pressure drop (psi) or friction loss in pipes or tubes.
Major and minor loss in pipes, tubes and duct systems.
Calculate hydraulic diameter for rectangular ducts - metric units.
Reynolds number for clean cold water flow.
